#21 | |
ampman
Trade: providing pathways for electrons and protons
Re: Why Does Code Note Require Gfci Breakers On Electric Water Heaters? 2Quote:
an army of sheep lead by a lion will defeat an army of lions lead by a sheep |
#22 | ||
Trade: Control Systems
#23 |
Only electrons move around helter skelter from the nucleus. It takes a quatuum mechanics and nuclear reactions before protons move around.
#24 | |
Fentoozler
[NOTE: This is NOT my PowerPoint Presentation...I DO have permission from the author to send it out]
#25 | |
Trade: Master Electrican, Electrical Contractor
![]() But don't try to comment about it until understand it ok? Same goes for the unrelenting thank you buttons....... |
#26 |
Re: Why Does Code Note Require Gfci Breakers On Electric Water Heaters? 2 |
#27 |
Not so fast Genius Macmikeman, there seems to be no way to add an attachment via the pm method... Ok Celtic, tell me the path and I will send it to you.
| The Following User Says Thank You to macmikeman For This Useful Post: | Celtic (10-02-2009) |
#28 |
Fentoozler
Thanks Mac....I have it.
I didn't have it ~ because the comp. that it was on took a dump ~ but George had a link on one of his FAQS...so now I do have it. ![]() Did ya follow all that? ![]() TY again
#29 |
Sorry I ducked out for a while in order to pollute the sister site with some more of my nonsence..... Glad you found it.
#30 | |
Fentoozler
#31 | |
Trade: Solar/Electrical
Still this is a simplification because electrons are really waves and only have a certain probability of being anywhere at any time and it all works as a sort of average of the positions of the electrons, not really for specific electrons which could be doing all sorts of crazy things. That's my 2 cents anyway, but I'm not a physicist or anything. ----- Also, seems to me that there are cases where GFI could protect people in a lot of areas where they aren't used. Any fault to an improperly grounded appliance located near a properly grounded appliance sets up a situation where a GFI could prevent shock. A loose neutral at the panel or transformer could set up a situation where a GFI could prevent a shock to anyone working on the plumbing. Of course GFIs aren't fool proof and you can still get shocked if you are part of the circuit between hot and the correct neutral, but it doesn't seem unreasonable to say that GFIs should be more widely used. That's my 2 cents anyway, I have a C10, but I really only do solar. (The inverters have ground fault protection) Last edited by newenergy; 10-03-2009 at 01:12 PM. |
| Power vent vs. electric water heater. | osborn | Plumbing | 8 | 03-02-2007 11:04 AM |
| Tankless water heaters? | Tenspound | Plumbing | 20 | 06-21-2006 11:37 PM |
| chase for water heaters? | deox719 | HVAC | 3 | 02-23-2006 07:23 PM |
| Electric Baseboard Heaters available | LNG24 | Contractor Swap | 0 | 02-05-2006 01:44 AM |
