What The Heck Is This? - Page 2 - Electrical - Contractor Talk
Old 03-15-2010, 03:48 PM   #21
Wasting Time
Knighton's Avatar
Rewards Points: 75
Re: What The Heck Is This?
Originally Posted by Inner10 View Post
The beauty of an RF system is that it doesn't need wires. You can rip out or cutoff thoes lowvoltage wires and disregard them.
Most RF lighting systems work like this:
You connect the load to the dimmer, the dimmer can receive a signal to tell it to turn on off dim etc. It can also send its signal back to report its status.
After you replace the dimmers or switches with the RF ones, then you install a keypad in the wall instead of the old LV thing. Most keypads need either a LV power supply or line level direct to them. When you press a button on the keypad it (depending on the system) it sends a signal to a dimmer telling it to perform that action.
The only wiring difference is that most of them use a dimmer or switch on the load, then for 3 or 4 way switching you install "keypads" that look identical to the switch/dimmer. The keypad wirelessly tells the dimmer/switch the necessary command. Functionally it works exactly like a standard 3/4 way switch but you do not need travler wires going between all of the 3/4 way switches, they now only need constant power to broadcast the command to the dimmer/switch controlling the load.
Make sense?
I see. I guess I thought there would be some magic to it. If I've got to tie into the load, then I could just as easily run a normal switch. However, if it were for a 3-way, then this would be the better choice.
Thanks again for your help.
Knighton is offline
Old 03-15-2010, 04:07 PM   #22
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 13,406
Personally I would tie into the load anyway, I was trying to figure out a way to add back in the lighting control w/o additional wires. If you want to keep the LV system I'd have to see the wiring to figure out if it could be done with an RF based system with dry contact closures.
Inner10 is offline
Old 03-16-2010, 10:40 PM   #23
220/221's Avatar
Trade: electrician Phoenix AZ
I don't know what it is but it goes to twelve
http://www.youtube.com/v/EbVKWCpNFhY...</param><param
Just because it's within code doesn't make it safe.
Just because it's against code doesn't make it unsafe.
220/221 is offline
The Following User Says Thank You to 220/221 For This Useful Post:
Diamond D. (03-17-2010)
DW718 Heck of a deal @ Lowes...you heard me Lowes CrpntrFrk Tools & Equipment 23 08-28-2009 02:50 AM
What the heck is wrong with my website? Pro Builder Websites and SEO 13 08-15-2009 02:23 PM
What the heck is this? Michaeljp86 General Discussion 40 07-17-2009 08:05 PM
What the heck do I do now? superdeez Off Topic (Non Trade) 31 04-06-2009 12:43 PM
What the Heck? MrRoofer Roofing 3 03-04-2009 09:22 AM
