What To Expect From Remodel Inspection
Old 06-23-2009, 11:51 PM   #1
Builder
Hatter's Avatar
Trade: Builder/Remodeler
I run construction jobs all the time but usually new construction, so I am not sure what to expect on an electrical inspection when the walls are not open. I am planning on rerunning the entire house myself under homeowner permit, so I am curious what the inspector will look at? I don't need to open any walls b/c it is ballon framed without fire blocking, so there will not be much to look at.
Thanks
Hatter is offline
Old 06-23-2009, 11:59 PM   #2
Pompass Ass
bwalley's Avatar
Re: What To Expect From Remodel Inspection
Thanks
How are you going to anchor the wire?
bwalley is offline
Old 06-24-2009, 12:59 AM   #3
philcav7's Avatar
Trade: Home Theater Design & Installation
If I am not mistaken, the requirements of cable supports/securing and nail plates does not apply if there is not access to install them in a remodel/retrofit application.
Home Theater Install & Sales: NYC, North Jersey, NE PA
Control4, Yamaha, Denon, Vienna Acoustics, Sonance, Mirage, Energy, Polk Audio, Sony, Mitsubishi, Samsung, Panasonic, Toshiba, LG, Dalite, Stewart Filmscreen
philcav7 is offline
Old 06-24-2009, 06:40 AM   #4
Custom Stuff
Mike(VA)'s Avatar
Trade: General Contractor - Custom Renovations
One thing is you may NOT want to open any more of the walls than is necessary. The possibility exists that you could get the HO involved in code capture. I have never been involved with a whole-house re-wire without breaking the walls so I would suspect it will come down to how the inspector feels that day. Old work boxes are perfectly fine for remodel work, make sure exposed wire is anchored properly, and have j-boxes with the covers nearby. Biggest issue will be grounding and the service panel, same as in any other construction.
__________________________________________________ ___________
I EXPECT THAT SOMEDAY I WILL SEE THE FRUITS OF MY LABOR. IS IT SOMEDAY YET?
Clifton, Great Falls, McLean, Fairfax Station, Manassas, Virginia Renovation Contractor
Mike(VA) is offline
Old 06-24-2009, 07:11 AM   #5
TxElectrician's Avatar
Trade: Electrical
so this is your house?
TxElectrician is offline
Old 06-24-2009, 07:39 AM   #6
Anti-wingnut's Avatar
Ditto that question!
Anti-wingnut is offline
Old 06-24-2009, 08:00 AM   #7
You did what??
J F's Avatar
nah, he was just the lowest bidder...."we don't need no stinkin' electricians...thems costs money dammit!!"
J F is offline
Old 06-24-2009, 12:19 PM   #8
Builder
Hatter's Avatar
Yes, this is my house- not doing anything shady. I just bought the house(1879 farmhouse) and was not planning on redoing the wiring but I am moving the location of the stairs and during which I found some knob and tube wiring and taped exposed splices in the ceiling. My thought is that if it was done here- who knows what else was done- so replace everything even though it is not in the budget.
As far as anchoring the wire- that is part of my question. I have been told before the same thing that Phil said, but just want to double check.
Hatter is offline
Old 06-24-2009, 01:26 PM   #9
You did what??
J F's Avatar
Go to the "electrical section" and ask, they're very helpful to non-electricians there...
p.s. make sure your life insurance is paid up first
J F is offline
Old 06-24-2009, 01:27 PM   #10
You did what??
J F's Avatar
...also check out the "plumbing" section...very helpful as well
J F is offline
Old 06-24-2009, 02:06 PM   #11
And I do electrical, too!
480sparky's Avatar
What to expect from a 'remodel' inspection depends on what standards your AHJ has adopted.
Obviously, anything you do must be up to current NEC levels, but how much must be done depends on what the AHJ has deemed necessary. Some want the dedicated small appliance and bath circuits. Others just want receps grounded. Some require AFCIs installed to 210.12 and TRRs from 406.11.
It's best to avoid any problems and invite the inspector over before you start work. This will make both your jobs 110% easier.
Site : the area or exact plot of ground on which anything is, has been, or is to be located.
Sight : The power or faculty of seeing; perception of objects by use of the eyes; vision.
Cite : To mention in support, proof, or confirmation; refer to as an example.
480sparky is offline
The Following User Says Thank You to 480sparky For This Useful Post:
Hatter (06-26-2009)
Old 06-24-2009, 03:45 PM   #12
Service & Repairs
Magnettica's Avatar
Trade: Electrician
480 summarized that very well.
Magnettica is offline
Old 06-24-2009, 05:56 PM   #13
ampman
ampman's Avatar
Trade: providing pathways for electrons and protons
you would be better off to hire a pro it will be cheaper in the long run
an army of sheep lead by a lion will defeat an army of lions lead by a sheep
ampman is offline
Old 06-24-2009, 07:48 PM   #14
Thom
thom's Avatar
NO NO NO. Long runs aren't cheaper. We must upsize our wire, that's more expensive. It's more expensive in long runs.
I think I need another beer.
thom is offline
The Following User Says Thank You to thom For This Useful Post:
ampman (07-20-2009)
Old 06-24-2009, 10:05 PM   #15
woodchuck2
woodchuck2's Avatar
X2, ask him what he wants to see and make it worth his time to talk to you. I give my inspector a tip every time i see him for a coffee or a beer. This goes a long ways when it comes to calling him for any questions you may have.
woodchuck2 is offline
Old 06-27-2009, 12:02 AM   #16
huntington beach, ca.
hbelectric's Avatar
Trade: electrical
Standard stuff, keep wires 6' away from attic access, or protect them. Make sure kitchen has required circuits, can lights IC rated., ground all switches, recepts and staple any exposed wires, in attic also. exterior outlets and outside lights must be on a photocell type deal. Title 24 kitchen lighting, hallway lights dimmer.
hbelectric is offline
Old 06-27-2009, 12:06 AM   #17
480sparky's Avatar
Originally Posted by hbelectric View Post
........exterior outlets and outside lights must be on a photocell type deal. Title 24 kitchen lighting, hallway lights dimmer.
Huh??????
Old 06-27-2009, 03:21 AM   #18
hbelectric's Avatar
Trade: electrical
Originally Posted by 480sparky View Post
Huh??????
I was watching the baby sorta in a rush.
When I used to do code updates, you needed front and back outlets.
Outside lights to be photocell type, kitchen lights title 24( which is basically flourescent), and hallway lights on a dimmer.
Basically what i said.
Old 06-27-2009, 09:19 AM   #19
480sparky's Avatar
According to............?
Old 06-27-2009, 02:34 PM   #20
#1 stunner
Static Design's Avatar
Trade: Design/Build
Send a message via AIM to Static Design
what?????????
Will do autocad/ 3d work for food.
SD on facebook... click here
Static Design is offline
Shared Sump (Dewatering) and Sewerage Ejector Pump Michael Thomas Plumbing 22 03-31-2009 09:56 AM
Google Seminars For Success... Ivinni Marketing & Sales 193 02-07-2009 08:22 PM
Anyone done Wal-Mart remodel painting ca6301 Painting & Finish Work 2 09-05-2008 11:58 AM
Inspection Scheduling fireguy Business 3 11-11-2007 10:38 PM
