Trade: drywall finishing
What Are The Code Requirements?
Hey guys, I hope you can help me out here. What is the required height off the floor for receptacle boxes and light switches? I am totally gutting my place and remodeling, and I am ready to start putting things back together. I am a drywall finisher by trade, but I never measured these things, LOL. I am not going to do the the wiring, but I can install the boxes, etc, in the mean time. I'm doing this on my own time, so just trying to do what I can when I get a chance too. Any help would be great. I know it's probably in here somewhere if I searched, but it's 2:30 a.m. and I don't have the patience right now to read through a bunch of posts to find it.
Also, I'm in central PA Thanks again Mike |
Trade: Electrical, licensed with master's, journeyman and maintenance.
Re: What Are The Code Requirements?
For receptacles, there is no rule on height off the floor . Code requires switches to be no higher than 6' 7' off the floor.
#3 | |
Baltimore Electrician
Trade: Electrician
There are also ADA requirements. (Americans with Disabilities Act) This wouldn't be an issue in single family dwellings, but could be in other occupancies.
I don't know the requirements off the top of my head, and can't seem to find it with a quick Google, but they have probably been posted here before.
John from Baltimore "One Day at a Time" All replies based on the 2008 NEC Quote:
4.2.5* Forward Reach. If the clear floor space only allows forward approach to an object, the maximum high forward reach allowed shall be 48 in (1220 mm) (see Fig. 5(a)). The minimum low forward reach is 15 in (380 mm). If the high forward reach is over an obstruction, reach and clearances shall be as shown in Fig. 5(b). Appendix Note
4.2.6* Side Reach. If the clear floor space allows parallel approach by a person in a wheelchair, the maximum high side reach allowed shall be 54 in (1370 mm) and the low side reach shall be no less than 9 in (230 mm) above the floor (Fig. 6(a) and (b)). If the side reach is over an obstruction, the reach and clearances shall be as shown in Fig 6(c). Appendix Note http://www.access-board.gov/adaag/html/adaag.htm#4.2
#5 | |
Trade: Electrician
Thank you Teetor.
Electrical Contractor
Trade: Electrical
As an electrical contractor it would be of no help to me to have the boxes installed by someone else. In fact it would proabbly be more work for me for two reasons.
#1 I would have to change boxes that were not the proper size or in the correct locations. Or #2 I would have to spend time with you telling you exactly what and where, when I could just nail the box up myself faster than it would take to go over everything with you.. |
Trade: Electrical
I know. Folks think they will save all this money by doing some of the job themselves. I hear that all the time: "I'll set the boxes and pull the wire. You can do the "hook-ups"".
I politely say: NO thank you.
In most places you CAN do the wiring in your own home, even build your home from the dirt up.
#9 | |
Trade: Electrical
Re: What Are The Code Requirements?Quote:
Trade: Electrical
Re: What Are The Code Requirements? |
Trade: electrician Phoenix AZ
16" and 48" to the bottom is what I generally do.
If I had it my way, the receps would be at 48" too for easy installation.
Just because it's within code doesn't make it safe. Just because it's against code doesn't make it unsafe. |
#12 | |
why do my living room look like a garage! ![]()
Mamma would love it. No more bending over to plug in the vacuum
Yo' Mama!
Could you imagine what it would look like to have your average entertainment center or computer station plugged in at 48"?
Fentoozler
That is not entirely true
...210.52 210.52(C)(5)
#18 |
Hey guys, thanks for the replies. As far as would it be faster to just have the electrician do everything, it probably would, if I was doing the entire house at once, since I'm paying out of pocket as I go, wiring one room at a shot is what's going to happen. Also, the guys helping me do this are coworkers at my plant, they are all licensed in the various trades, electrical and plumbing etc etc. Therefore I get their assistance as they become available.
MdShunk, we talked before, I live in Tower City, you said that you used to work at AMP here. So I'm in Schuylkill County, if I were to spit in a westerly direction, I could probably get Dauphin County, LOL. Thanks again, Mike |
#19 |
Master Electrician
Trade: Electrical
Sounds weird but I use my belly button to bottom of switches and Top of Hammer O' Day for bottom of rec. It turns out real close to 48" and 16" if I use a tape measure. As long as I don't shrink during the day or I accidently grab another hammer I'm fine..
| Did you Know CA Laws on License + Unlicensed Contractors | eagleandbaby | Contractor Licensing | 65 | 03-27-2010 11:44 PM |
| 2 questions - one code, one structural | karma_carpentry | Decks & Fencing | 5 | 09-10-2006 02:55 PM |
| Code books?? | Luke's Dad | Construction | 15 | 06-25-2006 10:14 PM |
| Code Requirements - Fun! | Steve Nyhof | General Discussion | 2 | 11-17-2005 09:11 AM |
