tags, as close as possible to the opening tag. Creation Date: 12/20/2017 -->
Want To Replace Switch With 5245
Old 01-18-2017, 01:59 PM   #1
skyhigh82's Avatar
Trade: Home Inspector
Rewards Points: 16
Is there a way to replace this Three way switch with Leviton 5245 and have the outlet powered all the time.
skyhigh82 is offline
Old 01-18-2017, 02:04 PM   #2
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 10,408
Re: Want To Replace Switch With 5245
A photo of the switch tells us nothing. We need to know where all those wires go.
Why is there not a Flat Mars Society?.
480sparky is online now
The Following User Says Thank You to 480sparky For This Useful Post:
Fouthgeneration (01-18-2017)
Old 01-18-2017, 02:05 PM   #3
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 12,383
I think it's half of wall receptacle on a 3 way....or the whole thing. Just a guess.
MarkJames is offline
Old 01-18-2017, 02:11 PM   #4
skyhigh82's Avatar
Rewards Points: 16
R,W, B on switch go to another three-way switch. W&B wired together i believe is coming from two lights where the power source is coming from.
Three way switch control two lights powered through lights.
Old 01-18-2017, 02:11 PM   #5
480sparky's Avatar
It appears there's no grounding conductor. Therefor, you cannot put a receptacle in. NEC 406.4(A).
Old 01-18-2017, 02:17 PM   #6
MarkJames's Avatar
Old 01-18-2017, 03:49 PM   #7
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,875
Looks to me like there's one peeking out at the back of the box.
Tinstaafl is offline
Old 01-18-2017, 04:08 PM   #8
480sparky's Avatar
I got a nickel that says it's not 300.14 compliant.
Old 01-18-2017, 04:10 PM   #9
skyhigh82's Avatar
Rewards Points: 16
There are, screwed to the back of the box, just didn't pull them out.
Old 01-18-2017, 04:20 PM   #10
Fire up the BBQ
griz's Avatar
Rewards Points: 1,212
how far do they extend out of the box?
griz is offline
Old 01-18-2017, 04:23 PM   #11
TxElectrician's Avatar
Trade: Electrical
Rewards Points: 1,310
Is there a grounded conductor?
Sent from my SM-G900P using Tapatalk
TxElectrician is offline
Old 01-18-2017, 04:24 PM   #12
skyhigh82's Avatar
Rewards Points: 16
Yeah, I know, home built in 60. They don't, about 2-3" inside the box.
Old 01-18-2017, 04:49 PM   #13
Trade: Electrical
But what about a grounded conductor
Old 01-18-2017, 04:52 PM   #14
skyhigh82's Avatar
Rewards Points: 16
Sorry, miss read, no neutral/grounding conductor
Old 01-18-2017, 04:54 PM   #15
480sparky's Avatar
Neutral = grounded.
Ground = grounding.
Without a neutral/grounded conductor, you're hosed.
Old 01-18-2017, 04:54 PM   #16
Trade: Electrical
Wont work with existing wring
Old 01-18-2017, 05:04 PM   #17
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Builder/GC
Rewards Points: 90
Then what are the black and white conductors wire-nutted together in the bottom right of the photo?
Delta
I have an Edifice Complex.
Old 01-18-2017, 05:18 PM   #18
Trade: Electrical
Delta
Old 01-18-2017, 06:01 PM   #19
MarkJames's Avatar
Never mind.
Old 01-18-2017, 06:07 PM   #20
rselectric1's Avatar
Rewards Points: 574
Delta
Just one example of why wire colors that are not "typical" need to be re-identified. One inch of electrical tape if done correctly would give us the most likely answer just from the picture.
rselectric1 is offline
The Following 2 Users Say Thank You to rselectric1 For This Useful Post:
cwatbay (01-18-2017), Seven-Delta-FortyOne (01-18-2017)
Need help with saw switch Irishslave Electrical 15 04-02-2013 11:02 PM
I need to add a ceiling light to a switch that activates an outlet supafly917 Electrical 23 12-10-2012 04:03 PM
Titan 440i Filter Replace artinall Painting & Finish Work 10 07-24-2012 10:15 PM
Double Pole Switch jproffer Electrical 20 04-02-2011 09:56 AM
Multiple fixtures on switch loop KenHaynes Electrical 2 12-05-2007 02:15 PM
