Wall Oven Breaker Question
Old 11-29-2008, 07:42 PM   #1
Parem's Avatar
Trade: construction
am installing a GE wall oven and have a question regarding breaker size.
its a 220v 6.2kw, install sheet says use 30amp breakers and the feed
from panel is #10 awg but the wires from the unit to the outlet are
only #16 awg. seems thin to me.
could someone shed some light on this? do i use 30amp breakers?
Parem is offline
Old 11-29-2008, 07:52 PM   #2
genexelectric's Avatar
Trade: electrical contractor
Re: Wall Oven Breaker Question
yep if its copper #10 wire from panel then 30 amp it is factory has diff specs on wire just jike your local utility provider. the wires on the oven are prob heat treated and are rated in diff catagory
genexelectric is offline
Old 11-29-2008, 09:01 PM   #3
Fentoozler
Celtic's Avatar
It is thin...but the internal wiring of appliances is not subject to the NEC.
Celtic is offline
Old 11-29-2008, 09:55 PM   #4
Service & Repairs
Magnettica's Avatar
Trade: Electrician
110.3 (b)
Magnettica is offline
Old 11-29-2008, 10:59 PM   #5
acrwc10's Avatar
Trade: Electrical contractor/General contractor/ ICC certified electrical inspector
Actually a 30 amp breaker seems kind of small for 6.2kw but the manufacturers instructions out weigh all.
6.2kw =6200watt / 240 volt = 25.833 amps
25.833amps X 125% (continuous load) = 32.29 amps Normally you would "one up" to the next standard size breaker not one down.
acrwc10 is offline
Old 11-29-2008, 11:04 PM   #6
Handle It!
MALCO.New.York's Avatar
And we are assisting a DIYer because??????????
Ultimate Wisdom---------
MALCO.New.York is offline
Old 11-29-2008, 11:32 PM   #7
Fentoozler
Celtic's Avatar
Since when is a range/cooktop considered "continuous"?
Celtic is offline
Old 11-30-2008, 08:56 AM   #8
Electrical Contractor
Speedy Petey's Avatar
Trade: Electrical
And even if he is not a DIY he is obviously not qualified to be doing this work for customers.
Speedy Petey is offline
Old 11-30-2008, 09:09 AM   #9
Handle It!
Precisely my sentiment!!!!
There are times when I have said or asked some stupid things concerning Electricity, but NEVER in reference to an actual application that my kill someone.
Call a Sparky!!! (That was NOT easy for me to say!!!)
Old 12-01-2008, 03:00 PM   #10
Parem's Avatar
Trade: construction
thanks, diff wiring spec/heat treated sounds plausible to me.
the install is for myself, am building my retirement home from the dirt to the ridge vent caps and yes their has been a few questions on the way.
the GE unit is the only one i noticed with 16 gauge, thats all.
don't think this is a stupid question as several electricians couldn't tell me
so i asked here for better odds.
Parem is offline
Old 12-01-2008, 03:06 PM   #11
Fentoozler
Celtic's Avatar
.... so i asked here for better odds.
Moving to Vegas?
Celtic is offline
Answer a Question with a Question Nathan Off Topic (Non Trade) 151 10-07-2008 03:07 PM
wall panel around bullnose kevbo Finish Carpentry 2 08-30-2008 09:04 PM
Breaker and wire size for built in oven airgrabber Electrical 13 11-08-2007 11:53 PM
removing a none load bearing wall?? samiam Framing 7 09-12-2007 08:33 AM
Backyard office, retaining, and privacy wall Team Scream Masonry 8 08-02-2007 11:27 PM
