listen twice talk once!
Trade: electrician
Voltage Leak
I worked at a school today where a teacher had been complaining that the emf emissions where to high and even had it down to two panels one classroom over! So I was told you could measure it buy putting all three hots and the nuetral in an amp probe and you would get a high reading. So I did that to all the branch circuits in a 2000 amp switchgear. Ten I think. They all read close to 0 mostley around .2 amps ........except 2 of them which were around 2.2 to 2.8 AND it was even the two panels the teacher had said. So I opened them up and megged out the feeders, they were ok then as I was going to do the nuetral i realized it was landed on the ground bar and then went to the nuetral bar. Probably cause it was cut to short. So I extended it with a splitbolt and taped it up. Now I tested it again and with all four wires in the feeder under my amp meter it was back down to .1 amps. So I had never even heard of this until friday afternoon, is the problam fixed and what some other people experiences with this problam?.........go wings!
DGFVT
Trade: Electrical
Re: Voltage Leak
You solved at least part of the problem with high EMF. What you need to do is go look for some more. More high magnetic field environments are created by electrical and grounding system problems than by power lines. This is true in both commercial and residential settings. In commercial buildings, the problem usually results from unbalanced feeders and branch circuits. In residential buildings, both single family homes and apartments, the most common problem is neutral current flow on metallic plumbing and grounding systems. Improper electrical wiring configurations are a frequent problem in all building types.
Carry on Dude, your hot on the trail of the problem. |
Trade: electrician
Re: Voltage Leak
How is emf measured? And besides severly unbalanced load what are some other mistakes electricians make that cause high emf? thanks bk....................go wings
#4 | |
Re: Voltage LeakQuote:
Thanks ........................ just courious.
#5 | |
DGFVT
Trade: Electrical
Remember to use good wire practices and that “Someone has been there before you and he might not of done it right”. Here is a link to a meter to measure EMF/ELF: http://www.wallcoinc.com/Extech_4808...al3-480823.htm Carry On |
Outreach Trainer
Trade: Electrical/Safety
Re: Voltage Leak
What was the ARC rating on the 2000A switchgear?
Trade: electrician
Re: Voltage Leak
KNow one knows how the teacher knew, But he is a computer teacher. and sorry I do not know the arc rating on the switch gear. But it was a brand new retrofit.
Electrical & Plumbing
Trade: Electrical and Plumbing contracting
Re: Voltage Leak
I ran into a similar problem many years ago at a doctor's office.
Anytime the the overhead florescent lights were turned on, there was a weird horizontal line of static that ran across the recently installed computer CRT monitors and slowly scrolled from bottom to top. The circuits were ran in type AC cable and the computers were on dedicated circuits with an isolated ground that ran all the way back to the main panel. We re-ran new circuits for the lighting, still no luck. Isolated the ground of the lighting, no luck. Eventually took the the grounds for the computers all the way back to the grounding electrode, which helped some but didn't fully solve the problem. Finally drove a totally separate rod for the puters, but that didn't completely eliminate it either. Eventually the Doc choose to replace the florescents with incandesent lighting and the problem went away. Never did figure out exactly what the cause of it was though, and felt pretty inept. But that was before I discovered Contrator Talk and all the really smart guys here that I could ask.
-Rhett Licensed electrician and plumber |
| High Voltage vs Low Voltage Lights | robertc65 | Outdoor Lighting | 16 | 04-04-2011 06:26 AM |
| Can I provide flood lighting via Low Voltage | robertc65 | Outdoor Lighting | 8 | 11-06-2007 10:42 AM |
| cat5 voltage | jdeihs | Low Voltage | 7 | 06-17-2007 03:26 PM |
| Voltage Sag mp3 | Magnettica | Electrical | 2 | 03-08-2007 06:39 PM |
| Leak in Ruud air handler in attic | Geeteex | HVAC | 1 | 03-17-2006 08:07 PM |
