Trade: C+M Electrician
Vehicle Mounted Generator Neutral Bond And Ground
Maybe some of you have come across this before. I am to install a 85kw 3 phase 120/208 generator (diesel powered) on a truck (24 ft straight truck). I will be installing a loadcenter 100A 3 phase 4 wire for distribution. If the generator neutral is internally bonded to the frame of the generator than there should be no neutral bond at the loadcenter. Here is the question: Is this a sufficient ground? The way I look at it is: this "ground" is not "really" a ground in the normal sense. My concern would be if the gennie is running and there was a short or poor neutral connection than there is an opprortunity for current to flow to a person touching the truck and the earth at the same time. And grounding the frame of the genereator to the frame of the truck could further complicate this? Sorry if it's confusing, I'm struggling with getting this out.
Trade: Squirrel Handler
Re: Vehicle Mounted Generator Neutral Bond And Ground
I have no idea but I think you would want it completely isolated from the truck.
On a side note (why I looked at this post), we have a sub-division a few blocks away that has a truck with a giant generator that comes and plugs into a large receptacle whenever there's a power failure. I have no idea what it's for, no hospital or old folks home in the area, any ideas? .
Some people climb mountains. I take out the trash. But we both do it for the same reason. |
#3 | |
Electrician
Trade: Electrical Contractor
Re: Vehicle Mounted Generator Neutral Bond And GroundQuote:
Trade: hvac
Is the vehicle being driven or mobile while generator running?? I know Hydro here will have a seperate ground wire with a short rod and of course in summer push it into the ground, that or if you wanted to be safe use a ground plate and maybe just slide it up against the tire and earth.
#5 | ||
My License Ain't 4 Sale..
InPhase277 Last edited by InPhase277; 03-07-2008 at 12:03 AM. |
#6 | |
InPhase277 |
Electrician
There is no restaurant in the ground that the electrons wish to go to. They wish to return to their source, and will use the ground to get there.
(One of my early instructors) |
Electrical Noob
Trade: Electrical
Ahhh... something up my alley!
I work for a mobile AC power company and outfit trucks similar to what you've got going on. We do bond the ground to the neutral in the load demand center. If it's good enough for Verizon, it should work for you!
2 Cor 13:14 |
Electrician
Re: Vehicle Mounted Generator Neutral Bond And Ground |
Trade: Electrical contractor/General contractor/ ICC certified electrical inspector
[quote=mickeyco; I have no idea
.[/quote] This is the most accurate thing you have ever posted !!!!!!!!!!!!!!!!!
#11 | |
#12 | |
It's "Copy and Paste". Although I have no idea what you are talking about. Any answers on my last question?
#14 | |
Electrician
Most generators now have GFCI protected receptacle outlets on the 120v circuits. So there would be little to worry about. Last edited by jrclen; 03-18-2008 at 09:59 AM. Reason: added the gfci comment |
