tags, as close as possible to the opening tag. Creation Date: 12/20/2017 -->
Using Dimmer Switch In A 4+ Way Circuit
Old 03-01-2008, 09:13 AM   #1
AustinDB's Avatar
Rewards Points: 594
finishing up a small job on my house and adding accent lighting to multiple rooms and want to control the lighting from multiple points. I've got the wiring down and understand using dimmers as the 3-ways is ok but question how the 4way's and 3way's will work in unison.
Let's say one of the 3way dimmers (first in series) is turned on 40%, and one of the 4way's is switched, the switch leg is powered off. Now switch the other 4way, does the light turn on at 40% or 100%?
Second scenario-same initial situation, but instead of switching on a 4way, the other 3way dimmer is switched on-does it regulate the voltage to whatever setting I choose (say 75%)?
AustinDB is offline
Old 03-01-2008, 09:40 AM   #2
Service & Repairs
Magnettica's Avatar
Trade: Electrician
Rewards Points: 2,002
Re: Using Dimmer Switch In A 4+ Way Circuit
Normally, only one 3-way dimmer can be used in the circuit you described.
However, I believe Lightolier sells (2) 3-way dimmers that can be used on the same 3-way lighting set up.
Magnettica is offline
Old 03-01-2008, 09:42 AM   #3
AustinDB's Avatar
Rewards Points: 594
after a bit more research, the Lutron Maestro's may be dimmable from multiple locations-up to ten. Can anyone confirm? Are they reliable?
AustinDB is offline
Old 03-01-2008, 09:49 AM   #4
Electrical Contractor
Speedy Petey's Avatar
Trade: Electrical
Rewards Points: 1,244
Yes they are. Several companies make these systems including Lightolier, Lutron and Leviton.
I've had Lightolier dimmers all over my home for over ten years.
Speedy Petey is offline
Old 03-01-2008, 10:08 AM   #5
acrwc10's Avatar
Trade: Electrical contractor/General contractor/ ICC certified electrical inspector
Rewards Points: 150
These are very good dimmers I have them in my own home and install them for customers all the time. Just fallow the wiring diagram they come with. If you get stuck the have a very helpful tech support line. They Maestro's also have a "Maestro IR" series that has a remote control very nice if you have an existing light that you can't or don't want to 3-way.
acrwc10 is offline
Old 03-01-2008, 01:03 PM   #6
Builder/Remodeler
ChrWright's Avatar
Trade: Builder/Remodeler
Rewards Points: 2,016
They work well and are reliable. They are wired differently than std 3-way and 4-ways.
On a reostat dimmer, you install only one dimmer on the light circuit and standard switches at the other locations. The 4-way switch location is travelers only and cannot hold the dimmer. When you turn on the lights from any location, the lights come on to whatever level the dimmer is set to.
With Maestros, all locations can be used to dim the lights. There is a master dimmer (with light indicators on the dim toggle), and multi-location slaves.
Each dimmer has a blue terminal for one of the travelers--these blue terminals must have continuity to each other to work properly.
Christopher Wright, CR: President @ WrightWorks, LLC
www.WrightWorks.net - Facebook - Twitter - Carmel Remodeling
Indianapolis Kitchen Remodeling Contractor - You Can Get There From Here
ChrWright is offline
Old 03-01-2008, 01:08 PM   #7
mdshunk's Avatar
These multiple location dimmers control the lights quite unlike regular swtiches. They use one of the wires to 'communicate' with each other. I've put in a few of the Lutron Maestro multiple location dimmers, but they're pretty expensive. Lightolier makes fine products too, but I seldom get to use them. Nobody in my area handles Lightolier, and the Lurton factory is just up the road a piece, so we generally use Lutron.
mdshunk is offline
Old 03-01-2008, 01:15 PM   #8
Builder/Remodeler
ChrWright's Avatar
Have you ever installed their RadioRA system, MD?
Old 03-01-2008, 01:28 PM   #9
mdshunk's Avatar
Once. It was customer supplied stuff. I have a hard time getting excited about anything that doesn't use as many wires as possible.
I have installed a few of their Graphic Eye sytems. Fancy-schmancy stuff, there. You need a certain kind of customer to get a bite on stuff like this. Most people want things that are famaliar or intuitive.
mdshunk is offline
Old 03-01-2008, 01:35 PM   #10
AustinDB's Avatar
Rewards Points: 594
when adding accessory dimmers in new construction, do you use 14/2?
The Lutron site shows installation instructions and it appears (to my untrained eye) they're using 14/3 with one of the travelers carrying the neutral. is that correct?
http://www.lutron.com/Instructions/030861b.PDF
in a new construction environment, when wiring additional Accessory Dimmers, w/o carrying the neutral, do you use 14/2?
AustinDB is offline
Old 03-01-2008, 01:37 PM   #11
Builder/Remodeler
ChrWright's Avatar
Pre-wire the same as you would for standard switches.
Old 03-01-2008, 01:39 PM   #12
mdshunk's Avatar
What he said.
mdshunk is offline
Old 03-01-2008, 01:48 PM   #13
AustinDB's Avatar
Rewards Points: 594
thanks for the replys guys-here's why I'm asking, the wiring diagram shows the load voltage is found at the end of the last switch and I'm trying to plan for adding on switch locations in the future (after additional spaces are remodeled). Would that then require a 14/3 and a 14/2 run to the new switch location (from an existing switch)?
thanks for the patience
AustinDB is offline
Old 03-01-2008, 01:49 PM   #14
Builder/Remodeler
ChrWright's Avatar
It is a mistake to assume what wires are for based on their color--particularly with multi-location wiring. If you don't have experience with 3-way & 4-way switching, you need to hire an electrian.
Old 03-01-2008, 01:56 PM   #15
AustinDB's Avatar
Rewards Points: 594
I figured it out, the problem is I'm not familar with electronic dimmers -this diagram better explained the role of the blue wire-now it makes sense http://www.lutron.com/wiringdiagrams/ShowWiring.asp?WD=12,20,21&Prod=MA-600-,&20MA-1000-,&20MALV-600-,&20and&20MALV-1000--
I can relabel my neutral as a load wire and carry the load back to the originating switch and all is well.
AustinDB is offline
Old 03-01-2008, 01:59 PM   #16
Builder/Remodeler
ChrWright's Avatar
Do you know the difference between commons & travelers? With Maestro, the commons are wired just as they would be for a standard switch...the travelers are as well--with the exception that all of the blue side travelers must have continuity with each other.
Old 03-01-2008, 02:10 PM   #17
AustinDB's Avatar
Rewards Points: 594
in every dimmer wall box the common is passed through so that the lighting load is hooked up at the end of the last accessory dimmer-in my case that is not where my lighting load is located-just like there's a number methods to wire a 3way circuit, I was just looking for the method that worked for my situation using the maestro.
thanks for the help
AustinDB is offline
Multiple fixtures on switch loop KenHaynes Electrical 2 12-05-2007 02:15 PM
Dimmer switch blowing out glock40 Electrical 4 03-13-2006 06:54 PM
smart light switch circuit toastermaker Electrical 7 12-07-2005 10:45 PM
