Upside Down Recep. Predicament??
Old 10-07-2007, 01:22 PM   #1
Master Electrician
Bubbles's Avatar
Trade: Electrical
We all know code is ground up. Occasionally when you do that homeowner/customer makes you go back and flip them the other way at your expense of course. If you put them ground down inspector might enforce the law! (like jaywalking). Had a case other day. Service call. 1/2 the upstairs went out. Started the process of elimination and at the end of 3 hrs and 23 rec./lights. We located a hidden recep. in closet the homeowner did'nt know was there (very hidden) her kid had little plastic chair up against it with gold chain around it slid down shorting hot to neutral. Point is code would have kept this one from happening in first place. Any other stories on this unenforced code predicament ???
Bubbles is offline
Old 10-07-2007, 01:30 PM   #2
Fentoozler
Celtic's Avatar
Re: Upside Down Recep. Predicament??
Do tell!
What code is this you speak of, grashopper?
...and shine some light of the HO issue of the freebie
Celtic is offline
Old 10-07-2007, 01:48 PM   #3
So you're the guy! Going replace cabinets for a customer, start to roll refer out to unplug it, POOFFTH! Cord was broken at 90º plug from strain of being plugged in up-side-down for too many years.
Also do I just then stand on my head if I wanted to read what it says on a GFCI outlet?
neolitic is offline
Old 10-07-2007, 02:18 PM   #4
Electrical Contractor
Speedy Petey's Avatar
Trade: Electrical
Bubbles, PLEASE tell me this is a joke and you are just looking to stir things up with a ground up/down war.........please.
Speedy Petey is offline
Old 10-07-2007, 02:26 PM   #5
Master Electrician
Bubbles's Avatar
Trade: Electrical
99.9% of time I put it ground down but logically ground up is better I think.
Here
http://www.mikeholt.com/technical.ph...%20or%20Ground
Bubbles is offline
Old 10-07-2007, 02:36 PM   #6
mickeyco's Avatar
Trade: Squirrel Handler
This was covered before, it's crucial that the ground holes face down or to the left.
mickeyco is offline
Old 10-07-2007, 03:04 PM   #7
Here
I will agree with this when everyone starts to hang their refrigerators,microwaves,toaster ovens,clothes dryers,window a/c's etc. from the ceiling. Or someone should share this with the folks who make appliance cords.
neolitic is offline
Old 10-07-2007, 03:36 PM   #8
Forry's Avatar
Trade: General Contractor, Remodeler
I'm told NEC requires ground down, while rec. manufacturers have rated the rec. for ground up only.
Forry is offline
Old 10-07-2007, 03:42 PM   #9
Trade: Electrical
This is a vastly different statement than your opening statement:
Forry, WHO told you this??? Whoever it was was WRONG on both counts. There is NO such NEC requirement.
Old 10-07-2007, 04:33 PM   #10
Forry's Avatar
Not sure, but I think it was an EC from a while back... and I've seen the exhibit 100.11 before. I don't often see outlets with the ground up, but I remember the conversation about hmmm... maybe it was U.L. listed? for ground up? I dunno, but at the time, I considered the source reliable.
Forry is offline
Old 10-07-2007, 04:35 PM   #11
mdshunk's Avatar
Pardon me while I go slit my wrists, since I've had to tolerate this stupid ground up/down thing for the one billionth time.
mdshunk is offline
Old 10-07-2007, 04:42 PM   #12
Union Electrician
Sparky Joe's Avatar
Trade: Inside Wireman
Code says nothing specifically about how to install a receptacle.....or how to install anything for that matter.
I've never read manufacturer instructions for installing a receptacle, but I have seen receps with the writing upside down.
Although if I trimmed a place with them all upside down, I would probably be back there to fix and thought of as a moron in the mean time.
Sparky Joe is offline
Old 10-07-2007, 04:49 PM   #13
Forry's Avatar
Agreed. We all know how it's usually done. I wouldn't want mine with the G up, It'd drive me crazy. Did have a commercial installation where it might've made sense though, rec. behind some ovens where sheet pans kept falling off the back of the ovens and tripping the main with a hard short. My EC suggested turning the rec upside down so the pans would hit the G if anything... I said bull*****, tell the bakers to stop throwing the pans off the back of the ovens... problem solved.
Forry is offline
Old 10-07-2007, 06:02 PM   #14
Trade: Electrical
Just remember one simple rule and you will NEVER be wrong:
THERE IS NO SUCH THING AS AN "UPSIDE DOWN" RECEPTACLE!
Old 10-07-2007, 06:06 PM   #15
Home Improvement Guy
ron schenker's Avatar
Trade: Renovations contractor
No don't MD you're too young to die
Don't worry, the baseboard will hide it!
ron schenker is offline
Old 10-07-2007, 06:18 PM   #16
mdshunk's Avatar
Thanks!
The 360 receptacles rotate. http://www.360electrical.com/#
mdshunk is offline
Old 10-07-2007, 07:22 PM   #17
GSE's Avatar
Trade: Electrical
You guys, just don't understand how it works, if the receptacle if upside down, you will need to cover it with alum foil, to prevent the electric from leaking out, (Actual call from customer that said his electrical bill had down down, since he covered all the outlets with foil, must be the same guy that heard there was a code on recptacle placement.
GSE is offline
Old 10-07-2007, 07:42 PM   #18
Fentoozler
Celtic's Avatar
Here
Dude...a poll is by no means remotely close to actual code.
I respect Mullin's opinion(and I do have some of his titles in my library) - but let's understand one thing first and foremost...it is only his opinion and NOT code.
If you want to follow his opinion, no problem.
Just don't erroneously assume it is "code" and preach it to the masses - that IS a problem.
</rant>
Celtic is offline
Old 10-07-2007, 07:45 PM   #19
Fentoozler
Celtic's Avatar
Really...take the time and look it up here:
Online Access to National Electrical Code® Softbound 2008 Edition (NFPA 70)
Alternately, you can provide reference from even one single manufac. that supports "what you were told". Just remember, that one single reference will apply to only that one single manufac. [NEC 110.3(B)]
Get your info straight from the horse's mouth ....we will be waiting for your reply.
Celtic is offline
Old 10-07-2007, 10:03 PM   #20
Old School Marine
randomkiller's Avatar
Trade: Union Journeyman Electrician
I was taught ground down as an apprentice, but just opinion. Ground up or down, who gets upset by either? What are we talking here four 6-32s max? If the appliance cord hangs right then I would say your done.
randomkiller is offline
VCT Tiles installed upside down Jaketoo Flooring 16 08-12-2007 04:46 PM
