Update On Unusual Ceiling Fan Job - Electrical - Contractor Talk
Old 09-03-2017, 07:01 PM   #1
back doors to hell put in
Irishslave's Avatar
Rewards Points: 2,632
Well hung one on the bottom cord of beam and it was too low even with the shortest down rod. Customer decides to put cross beams in and wants them hung on these....So after waiting weeks and then some more wiring the job get's done.....Well sort of
The pancake boxes on the bottom of the beam won't allow fan canopy to flush against beam....So I get fan wobble on high....as an after thought i thought about routing and insetting the pancake then the fan hanger bracket would be flush against the beam and likewise the canopy
If I omitted the pancake and just attached the hanger bracket I have no real place to ground the power supply unless I tapped the hanger bracket for a ground screw and that's a stupid idea
Television is fake...The internet is real
Irishslave is offline
Old 09-03-2017, 07:08 PM   #2
TxElectrician's Avatar
Trade: Electrical
Rewards Points: 1,706
Re: Update On Unusual Ceiling Fan Job
Hole saw, chisel, pancake, your done.
10 minutes tops.
TxElectrician is offline
Old 09-03-2017, 07:11 PM   #3
Irishslave's Avatar
10 minutes tops.
That should take the wobble out.......Yes?
The Following User Says Thank You to Irishslave For This Useful Post:
TxElectrician (09-03-2017)
Old 09-03-2017, 07:12 PM   #4
Trade: Electrical
If the fan is tight and balanced
Old 09-03-2017, 07:16 PM   #5
Irishslave's Avatar
10 minutes tops.
With my little magnet tray( so I don't lose screws) it shouldn't take long to disassemble the fan and reassemble, the canopy screws are the worst to feed in.
Out of the box these fans were a PITA...takes a good half hour to assemble the damn blades...got these stupid rubber grommets
Old 09-03-2017, 07:20 PM   #6
Trade: Electrical
Wait, wait, wait. No regular pancake, needs ti be fan rated.
The Following User Says Thank You to TxElectrician For This Useful Post:
hdavis (09-04-2017)
Old 09-03-2017, 07:26 PM   #7
Irishslave's Avatar
10 minutes tops.
That's exactly how you would have done it without even thinking about it ain't it?
I got one more to hang over there on the front porch anyway so I'll just rehang these hope it don't take too long.
Old 09-03-2017, 07:28 PM   #8
Irishslave's Avatar
I know that's the ones I used...they have a ground screw in them and tapped sleeves for the hanger bracket
Old 09-04-2017, 12:30 PM   #9
hdavis's Avatar
Rewards Points: 1,909
Fans go better with extra hands....
hdavis is online now
Old 09-04-2017, 07:15 PM   #10
Business Owner
P42003's Avatar
Trade: Pest & Termite Control
Rewards Points: 56
This is when it would be nice to have your own computerized plasma cutter. You could have steel platters cut that are slightly bigger in diameter than the shroud, along with a hole in the middle for the wires, four screw holes, and mount these first to the beam.
P42003 is offline
Crack at Peak in vaulted Ceiling Milhaus Drywall 21 11-04-2013 08:44 AM
Temporary Rafter Support for Clipped Ceiling TLyon Remodeling 17 09-12-2013 11:22 PM
paint flaking from the ceiling...cause/solution?? lornmastro Painting & Finish Work 27 02-26-2012 10:01 PM
Radiant Ceiling Heat - Drywall Falling Again CliffHollen Drywall 7 04-05-2010 04:18 AM
3-way wiring- ceiling fan with remote for two-wire hookup hevnbnd Electrical 29 08-17-2009 10:28 PM
