Universal Voltage Ballast
I been using some of the multi voltage ballast for a couple of months now and have not been impressed. The sylvania 3/2 lamp seems underpowered at 120 and fails at 277. The advanced intellivolt 4 pin 26 watt has a high failure rate and has been pulled off the shelf at our supplier.
I'm going back to 120 or 277 ballast for a while until I here better things about multi volts. I'd like to see a voltage indicator on future multi volt. I like to instantly know what voltage I'm dealing with. |
Re: Universal Voltage Ballast
I wish they'd just do a multi-tap and be done with this automatic voltage sensing nonsense. I find the electronic ballasts to have a much higher realized failure rate than the same ballast in magnetic. I'll sell an electronic retrofit job in a heartbeat, but I think the technology needs a little bit more iron in its gut.
Electrical Contractor
Trade: Electrical
Thank you
Last edited by Speedy Petey; 12-05-2006 at 12:35 AM. Reason: Offensive post by E1MASTER removed by mods. |
Trade: Master Electrican, Electrical Contractor
Daggomeit, I missed E-1's post. Word has it he is Da Man. Anyway, back to ballasts. What I have experienced is that the dual type set on 120 volt jobs tend to go bad sometimes when there is a spike from the poco. They get locked on the 277. Save em for replacement jobs on commercial.
#5 | |
Re: Universal Voltage BallastQuote:
I installed an intellivolt t8 ho tonight and it didn't want to start but finally did. I think it will be dead by next week. At a hundred dollars a pop the things should work. |
Union Electrician
Trade: Inside Wireman
Never heard of a T8-HO, but then there's lots of things I haven't heard. Do you mean T5?
I just noticed that he said H.O. I never heard of them before either. I just looked up T8 HO, and they in fact exist. Learn something new every day. I didn't know that 96" T8 lamps existed until a few months ago when I put some fixtures in that were customer spec'd that took 96" T8 lamps. Now that's a high dollar lamp.
Union Electrician
Re: Universal Voltage Ballast |
I don't keep spares in the van, silly. I do transport fluorescent lamps in the case that they come in to prevent breakage, even if I only need one or two from the case. That's one reason how I knew that the 96" T8's were expensive, because I had to buy a case. I only needed 8 lamps. Those lamps were around 10 bucks a piece, my cost. That was about a $250 case of lamps.
The t8 ho comes in 4'or 8'. I use mostly 8' with 4's on the ends.
I'm no fan of 8' lamps but when you look at 2 8's covering the distance of 4 4's they are not so pricey. In the days of 2-lamp only ballast, 8' lamps and ballast were cost effective. Even today I've only seen 2 lamp ho ballasts so running a quater mile of ho's would be less expensive using 8 footers. I found my t8 ho 8' ballast for $32 instead of $88. GE Proline. Looks like they wire up parallel with 3 leads out so they should light with only one lamp in place. That will be nice in an ho. They are still uni-volt but I think I'll try a few. Last edited by K2; 12-07-2006 at 01:00 PM. |
Union Electrician
So how many watts are these T8-HO's (4 footers)?
We did a job earlier this fall, the print spec'd out T8 6 lamp high bays, we had over a hundred installed when we had to do some body work on one and finally noticed they were all T5's. Big problem; seeing as they draw twice as much and everything was already circuited, and the motion sensor's and power packs were installed, and the power company had already given their 'kick-back' according to T8's. We kept the T5's and I'll say screw you if a foreman ever says I'm wasting time putting spare pipes on a rack. Little off subject, but just wanted to share, Thanks |
#12 | |
DGFVT
Trade: Electrical
#14 | |
Philadelphia electrician
Trade: Electrical contractor
they didn't have 120s and I had to get the repair done it took ten ballasts to fix 7 lights. what crap 2 just plain didn't work and one did the Haight-Ashbury strobe ... |
#15 | |||
![]() Trade: student again
They're available in 44W 4', 55W 5', 65W 6' and 86W 8'. The regular 265mA (or so) T8s are available in 17,25,32 & 40W. The 40W with the 17W being 1' and going up by a foot in each increment. I've never seen a 40W outside of catalog though. Quote:
Advance makes "Standard Electronic" which is 120 or 277v. REL-2P32-SC for 2 lamp 120v. These things are probably more resilient because the input is a coil-and-core type power factor corrector which absorbs surges to an extent... HOWEVER because of this power factor correction coil,(passive power factor correction) despite Advance's claim, these suckers hums just as bad or nearly as bad as magnetic ballast. These are also heavier and <20% THD rated. The "Centium" series used to come in 120 & 277v, but many of the dedicated ones are being discontinued and they're now 108 to 305v (120 & 277V +/- 10%). These are lighter and have a <10% THD rating. These are active power factor correction using high frequency electronic components. Something not mentioned on Advance site is that the Centium is a constant-power ballast, so the power usage and output remains the same at 110v or 130v With their standard series, the power consumption is affected significantly by input voltage, although if the voltage changes suddenly, it will flicker. This is both good and bad. The area lighting level remains unaffected by voltage and high line voltage doesn't increase power consumption, but these ballasts do not respond to planned energy saving voltage reduction at all. If the facility/utility reduces voltage 5%, the ballasts simply spits back at them by electronically compensating to draw 5% more current to draw the same power. Also, they're ABSOLUTELY SILENT, so by selecting wisely, you can ensure customer satisfaction. Quote:
#16 | |
#17 | |
For fluorescent setup, HO lamps are preferred since the higher energy density helps them stay at optimal performance temperature at the climate these lamps work |
#18 | |
#19 |
Trade: Electrical
I agree. T-5 HO high-bays are the wave of the future, along with other fixture types.
My supply house has on display a new 4' T-5 strip fixture (shop light) with a chrome reflector pan. Talk about BRIGHT!
#20 |
Check out the lighting on big box stores. Some Home Depots are using T5 HOs instead of metal halides.
| High Voltage vs Low Voltage Lights | robertc65 | Outdoor Lighting | 16 | 04-04-2011 06:26 AM |
| Can I provide flood lighting via Low Voltage | robertc65 | Outdoor Lighting | 8 | 11-06-2007 10:42 AM |
| cat5 voltage | jdeihs | Low Voltage | 7 | 06-17-2007 03:26 PM |
| Voltage Sag mp3 | Magnettica | Electrical | 2 | 03-08-2007 06:39 PM |
| Ballast for three F117T12CWHO lamps ? | bobbyp | Electrical | 3 | 09-16-2006 01:50 PM |
