Underground Repair
Old 09-22-2006, 04:49 PM   #1
kwoods's Avatar
Trade: electrical
Question
Underground Repair
I need to repair an underground feeder to a sub panel. It is 500 mcm wire in a 4" pvc conduit at 480 volts. I would like to put in a flush with grade splice box to repair the conduit. The wire is not broken, but is is skinned. The wire is type thhn so I don't think I can just use and underground splice kit without a box. The box that I am being advised to use is open bottom Quazite. It is in a lawn location with little or no traffic. Any advice or oppinions would be appreciated.
kwoods is offline
Old 09-22-2006, 04:54 PM   #2
mdshunk's Avatar
Re: Underground Repair
What's the operating voltage of these conductors? If it's just 240 or 480, and it was just skinned, I wouldn't hesitate to paint it with 3M's liquid electrical tape and cover with cambric. Repair the broken conduit in that area with the lineal split conduit repair sleeve.
You can splice 500MCM underground with a repair kit that has an H-Tap and a heat shrink sleeve. You need one kit per conductor.
If you want to do a grade level splice, the Quazite box would be my 1st choice too.
mdshunk is offline
Old 09-25-2006, 09:02 AM   #3
kwoods's Avatar
Trade: electrical
thanks for the advice. The way the conductors or all pulled back and the tight space I have to work with between building and sidewalk I need to go with a box.
kwoods is offline
Foundation repair (New business) Help! crosshair66 Business 10 05-18-2008 09:19 AM
Tool Repair Services madchad Tools & Equipment 0 08-15-2007 09:16 AM
After repair Repair dayspring Masonry 4 03-18-2007 02:24 PM
Chicago Home Repair License? Grumpy Contractor Licensing 24 09-15-2006 12:48 AM
Ok, ceiling repair Question Knyte260 Drywall 18 10-23-2005 01:15 AM
