Uf Depth
Old 02-22-2007, 08:59 PM   #1
osborn's Avatar
Trade: Licensed Home Improvement Contractor
Question
Uf Depth
Is there a NEC for the depth of uf cable?
osborn is offline
Old 02-22-2007, 09:08 PM   #2
Electrical Contractor
Speedy Petey's Avatar
Trade: Electrical
Re: Uf Depth
Only if you're burying it.
Speedy Petey is offline
Old 02-22-2007, 09:27 PM   #3
troubleseeker's Avatar
Re: Uf Depth
I am not an electrical contractor, so I hope one will correct if wrong, but I believe it is 18 inches.
In the real world, the required depth seems to have a general rule of thumb though... it seems to be required to always be four inches less than the depth of the trench the sprinkler guy is cutting. I never let our electrician use this stuff, PVC conduit is cheap.
troubleseeker is offline
Old 02-22-2007, 09:35 PM   #4
Teetorbilt's Avatar
Re: Uf Depth
I believe that 18" is the min. I always go 24" and use conduit.
Albert Einstein
Teetorbilt is offline
Old 02-22-2007, 09:42 PM   #5
Trade: Electrical
Re: Uf Depth
OK, I was being facetious since the question was so obscure.
The minimum cover requirements for UF cable are 18" in a residential setting, unless the circuit is GFI protected BEFORE it goes underground, then it is 12".
Old 02-22-2007, 09:48 PM   #6
mdshunk's Avatar
Re: Uf Depth
You'd think something so fundamental as burial depths would be cut and dry, but it's complicated. I went ahead and copied the actual table from the code, because it's hard to explain without the table:
mdshunk is offline
Old 02-22-2007, 09:50 PM   #7
mdshunk's Avatar
Re: Uf Depth
Sorry, Peter. I was busy scanning in the table while you replied. Didn't mean to step on your toes.
mdshunk is offline
Old 02-22-2007, 10:51 PM   #8
Trade: Electrical
Re: Uf Depth
No problem at all.
The table was a good idea.
Old 02-24-2007, 08:52 PM   #9
osborn's Avatar
Re: Uf Depth
Thanks! I better start digging. Sparkey will be here next week.
osborn is offline
Old 02-25-2007, 05:36 AM   #10
Union Electrician
Sparky Joe's Avatar
Trade: Inside Wireman
Re: Uf Depth
Sparky is already here
And it doesn't take more than a couple hours to dig a trench. And no mater what code says, be sure you get below the frost line to save trouble and aggravations down the road.
Sparky Joe is offline
Old 02-25-2007, 08:14 AM   #11
Trade: Electrical
Re: Uf Depth
Are you serious??? Where I am a 40' trench can take an hour in one spot. Go 5 miles away and that 40' trench can take all day!
Again, are you SERIOUS???? I aint diggin' no 4' deep trench w/o a machine!!!!!
Joking aside, are you really serious about getting below the frost line?
Old 02-25-2007, 10:34 AM   #12
mdshunk's Avatar
Re: Uf Depth
I can see some benefits of getting below the frost line, but not enough to where I'd ever make a ditch that low.
mdshunk is offline
Old 02-25-2007, 10:54 AM   #13
stars13bars2's Avatar
Re: Uf Depth
As previously stated, if it is 120 volts or less, 20 amp max and GFCI protected it would qualify for 12" of cover but, if its not a driveway or outdoor parking area for one and two family dwellings and this used for dwelling purposes only, the general rule for UF cable would be 24" of cover.
stars13bars2 is offline
Old 02-25-2007, 09:30 PM   #14
Union Electrician
Sparky Joe's Avatar
Re: Uf Depth
Around here frost doesn't get below 18 inches, I can't imagine how cold it must be to get 4 feet of frost.
Our dirt must be softer out west too. I dug a 200' trench 2 feet in half a day, and that was a lot of digging.
Old 02-25-2007, 09:36 PM   #15
mdshunk's Avatar
Re: Uf Depth
Dirt's different everywhere. There's no place around me where you could dig 200' at 24" in a half a day. In mountain ground, you can't even stick 1/4 of your shovel in the ground anywhere without hitting stones. In the valley's, there's lots of shale patches where you'd need a pick to loosen it up first. You'd be lucky to get 6 feet at 24" in a half a day by hand in that stuff. Hand digging is my absolute #1 most hated task. I'm just not built for it.
mdshunk is offline
Old 02-25-2007, 10:00 PM   #16
Union Electrician
Sparky Joe's Avatar
Re: Uf Depth
I don't look forward to it either, but when the dirt is soft it's a nice way to pass the time.
The trench I mentioned was part of a brand new place so the dirt had been worked by machines several times prior to me with my shovel.
Old 02-26-2007, 06:45 AM   #17
Trade: Electrical
Re: Uf Depth
There are two small parts of my town that are loamy sand. One is old farm land, now MANY houses. The other is the heart of the village.
You could dig all day and trench around the block. You can also push a ground rod in to about 2' and use a 20oz hammer to finish it.
The rest is exactly like Marc described.
Old 02-28-2007, 04:11 AM   #18
Union Electrician
Sparky Joe's Avatar
Re: Uf Depth
I've done some tunneling and lots of digging at my dad's place. The city he lives in is called "Sandy"(I'll give you one guess why)
Back when this entire area was covered by the prehistoric lake Bonneville, the rivers from the canyons made a 400' thick sandbar which is now called Sandy City.
Digging over there is like a dream, though growing things is not(huge water bill in the summer)
Lally column footer depth Second Look Construction 12 04-01-2007 12:29 AM
Circ Saw blade depth FP Home improv Framing 19 03-30-2007 10:43 PM
Well Pump Depth Question... thepawnshop Plumbing 9 08-13-2006 09:01 PM
Footing size and depth dproc Construction 11 03-08-2006 06:25 AM
Lentgth of landing on steps TROMPER Landscaping 2 09-11-2005 10:31 PM
