Trouble Shoot Tripping Breaker
Old 10-07-2009, 09:01 PM   #21
And I do electrical, too!
480sparky's Avatar
Re: Trouble Shoot Tripping Breaker
Originally Posted by DaVinciRemodel View Post
Twenty some years in the trades and this is a term I don't know.
Megger.
More to the point: Does your electrician know what it is?
Site : the area or exact plot of ground on which anything is, has been, or is to be located.
Sight : The power or faculty of seeing; perception of objects by use of the eyes; vision.
Cite : To mention in support, proof, or confirmation; refer to as an example.
480sparky is online now
Old 10-07-2009, 09:04 PM   #22
DaVinciRemodel's Avatar
Trade: Design/Build Remodeler
I'll quiz him tomorrow!
"Being willing is not enough; we must do". Leonardo da Vinci
Da Vinci on the web or Da Vinci On Facebook
DaVinciRemodel is offline
Old 10-07-2009, 11:01 PM   #23
Inner10's Avatar
Trade: Control Systems
I think the real name is megometer, they run a much higher voltage signal then a multimeter so you can test the insulation value of connection/wire.
If you had a ground wire that could be arcing against a live the megohmeter would help find it. Twice I've found clock plugs that had the live arcing against the ground WTF (I didn't install them but I did find out why the breaker kept tripping).
I recall doing a home theatre a few years back with a Lutron slider-dimmer and when you flicked the switch you could see a nice flash inside. The electrician said it was normal for switches.
Inner10 is online now
Old 10-08-2009, 08:56 PM   #24
He knows what it is - has one - but doesn't know if it will work in the situation.
He'll study-up and ask a few questions. He'll need to - breaker tripped again this afternoon.
Old 10-08-2009, 09:26 PM   #25
480sparky's Avatar
Uh, meggers are the first thing to find damaged wires, and these said damaged wires can cause an AFCI to trip..........
Old 10-08-2009, 09:50 PM   #26
Fentoozler
Celtic's Avatar
Send him over here ....he'll get more answers/info/opinion than he cares to get
Celtic is offline
Old 10-09-2009, 11:12 AM   #27
He's gone elk huntin for the weekend. There will be no updates until next week.
God I love this business!
Old 10-22-2009, 06:07 PM   #28
Electric_Light's Avatar
Trade: student again
This can be tough. My kitchen lighting breaker kept tripping and I couldn't figure out why. Turns out it was chaffed wire shorting to the frame in vent hood over the range. It would short out intermittently depending on vibration, temperature, etc.
Electric_Light is offline
Old 10-24-2009, 09:40 PM   #29
220/221's Avatar
Trade: electrician Phoenix AZ
I assumed you had some secret mojo or dance or special swear words you could pass-on to me to please the electrical gods
We do but we like to keep it a secret.
rekaerbralugerallatsni
Just because it's within code doesn't make it safe.
Just because it's against code doesn't make it unsafe.
220/221 is offline
Old 10-27-2009, 09:07 AM   #30
bfrosty's Avatar
Trade: Electrical
several of the same type situations on early Arc Fault breakers adn Ideal push in quick connector. (similar to Halo quick connectors) seemed that mechanical vibration had just enough effect on the tensioned spring, created enough ARC to trip the breaker after a year + or - a couple of months. Went through all cans and rewired with wing nuts.
bfrosty is offline
fridge tripping GFI dkillianjr Electrical 47 04-10-2009 07:46 AM
Noise from breaker Robie Electrical 13 04-07-2009 12:36 PM
GFCI breaker tripping at one temp but not another. BigJon3475 Electrical 14 07-06-2008 12:44 PM
Breaker keeps popping DErnest Electrical 2 09-15-2006 06:30 PM
Floor buffer tripping breaker bmartin Electrical 5 09-02-2006 01:19 PM
