tags, as close as possible to the opening tag. Creation Date: 12/20/2017 -->
Tricky Wiring
Old 10-26-2012, 08:29 AM   #1
Milhaus's Avatar
Trade: Residential Remodeling
Rewards Points: 254
Tricky Wiring
Hey - got a question for you guys about some wiring at home. I talked with my electrician about it but still haven't resolved it. I have a whirlpool tub that the motor is plugged into a dedicated 20 amp circuit. At the panel, it is on a split 20 amp breaker (the other side is the east wall of my kitchen - a couple outlets and the fridge). I don't have power at the whirlpool outlet for some reason?
Background - and the key I think - it was originally wired professionally and worked fine, but then I switched some things around to wire up my hot tub. I put it on the split breaker at that point. The motor hasn't worked since it was put on the split breaker. The motor works when plugged into a different circuit in my bathroom.
I've tested the outlet and the lines at the outlet - no power. I've switched the two hot lines at the split breaker to make sure the breaker wasn't bad, still had power at the kitchen but nothing at the outlet for the whirlpool. I took the kitchen line off completely and tried to run the whirlpool outlet - still nothing. Any ideas? Appreciate any advice.
mark
Milhaus is offline
Old 10-26-2012, 08:49 AM   #2
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 10,500
Re: Tricky Wiring
What time would you like me to set your service-calls appointment for?
Why is there not a Flat Mars Society?.
480sparky is online now
The Following User Says Thank You to 480sparky For This Useful Post:
fourcornerhome (10-26-2012)
Old 10-26-2012, 09:15 AM   #3
Milhaus's Avatar
Rewards Points: 254
Re: Tricky Wiring
haha
Milhaus is offline
Old 10-26-2012, 09:31 AM   #4
Frank Castle's Avatar
Rewards Points: 1,112
Re: Tricky Wiring
I'm no electrician, but do you have a disconnect box for the hot tub? Is there a blown fuse in the disconnect box?
Adapt, Improvise, Overcome.
Frank Castle is offline
Old 10-26-2012, 09:49 AM   #5
Milhaus's Avatar
Rewards Points: 254
Re: Tricky Wiring
Hot tub has its own disconnect box...and is wired correctly. Had the electrician check it out when I wired it up. On its own 50 amp breaker. Shouldn't have any bearing on the whirlpool dilemma other than I had to move some stuff around to put it in.
Milhaus is offline
Old 10-26-2012, 09:56 AM   #6
480sparky's Avatar
Re: Tricky Wiring
OK, now it's a HOT TUB instead of a WHIRLPOOL.
Whirlpools can operate on 120v, and most of them do.
Hot tubs usually need 240v.
So.......... my guess is........ your hot tub is now on a tandem breaker. Given that 99.9999% of tandem breakers out there have BOTH circuits on the SAME bus, you don't have 240v between the two hots. You will have 120v to ground, but since they're on the same bus, there's no 240V to be had.
Change the hot tub to a proper 2-pole breaker.
That'll be $200...... check or credit card?
Irishslave (11-14-2012)
Old 10-26-2012, 10:05 AM   #7
Thom
thom's Avatar
Rewards Points: 4,748
Re: Tricky Wiring
It seems he has both a whirlpool tub and a hot tub.
Is he calling a tandem breaker a split? Is he calling a 2-pole breaker a split? Is he a danger to himself and his community?
Patriotism is being loyal to your country all the time and your government when it deserves it. Mark Twain
thom is offline
Old 10-26-2012, 10:11 AM   #8
Milhaus's Avatar
Rewards Points: 254
Re: Tricky Wiring
The bill is adding up...we're talking about two different things here I think. The wiring for the whirlpool bathtub (originally on a dedicated 20 amp breaker) was moved into a split 20 amp breaker to accommodate adding the the hot tub (which was put in on a tandem 50 amp breaker and required another space to be put in). The hot tub runs fine. The whirlpool bathtub (originally on a dedicated 20 amp breaker) is now on a split 20 amp breaker and doesn't work. Unless I'm not understanding what you're saying about the bus bar, I don't think the whirlpool bathtub on the split 20 amp breaker has anything to do with it. Can I knock $20 off for the miscommunication?
Milhaus is offline
Old 10-26-2012, 10:22 AM   #9
480sparky's Avatar
Re: Tricky Wiring
Is the 'split' 20a breaker the same brand as the panel?
Originally Posted by Milhaus View Post
...... Unless I'm not understanding what you're saying about the bus bar, I don't think the whirlpool bathtub on the split 20 amp breaker has anything to do with it.
Tandem breakers usually won't connect to two bus bars to give you 240v. The vast majority of them only attach to one bus bar, and only will provide 120v to each circuit. Hopefully you didn't hook up a multi-wire circuit to the tandem.
Sure. I'll just add $60 for it.
Old 10-26-2012, 10:47 AM   #10
Re: Tricky Wiring
I don't know what I'm talkin' about. I was speed reading and missed the two different units and crossed problems. Don't listen to me!
Old 10-26-2012, 11:01 AM   #11
Milhaus's Avatar
Rewards Points: 254
Re: Tricky Wiring
Yes.
Understood. Hot tub is wired correctly as far as I understand it. Square D panel - installed in 2009 won't allow for a tandem 50 amp breaker to be a multi wire circuit, correct? Still doesn't help the whirlpool bathtub outlet situation (which applying the same theory - shouldn't have anything to do with the bus bar since they both have their own neutrals) so unless the wire is damaged in the wall - I can't figure out why there is no power to that outlet.
Dam electricians are expensive.
Milhaus is offline
Old 10-26-2012, 06:31 PM   #12
Handymen are people too
realelectrician's Avatar
Trade: electrician
Rewards Points: 356
Re: Tricky Wiring
Did you see if the GFI outlet was tripped?
If that's not the issue then I agree with 480sparky that the twin breaker is not giving you 240v because it's on the same leg/busbar.
Are you sure you have an electrician doing this work? A real one would solve this issue quickly.
realelectrician is offline
Old 10-26-2012, 07:52 PM   #13
rselectric1's Avatar
Rewards Points: 584
Re: Tricky Wiring
I hope there were no shared neutrals involved when you did this "switching around".
You could have a potentially overloaded neutral if it wasn't done correctly.
rselectric1 is offline
Old 10-26-2012, 10:15 PM   #14
Milhaus's Avatar
Rewards Points: 254
Re: Tricky Wiring
Thanks for the caution...I understand. I think my terminology may be confusing things. When I say split 20 amp breaker - I'm meaning a single pole breaker with two 20 amp circuits on it - what I think you're calling a tandem? The whirlpool bathtub is on this breaker on one side and the kitchen wall on the other. Each have their own neutral and ground.
The hot tub is on a completely different breaker - a double pole 50 amp taking up two spaces in the panel. From what I understand, a double pole breaker is designed and intended to be installed so it hits both bus bars, giving the safeguard from the multi wire circuit? Is that accurate? THe panel is a SqD Homeline installed in 09 by my electrician. I may be misunderstanding what you guys are saying - but why would I want the 20 amp single pole 'tandem' breaker to carry 240V? Each side should be at 120V, right? Why in the hell would they make it so the potential is there for an overload otherwise?
Milhaus is offline
Old 10-26-2012, 10:32 PM   #15
480sparky's Avatar
Re: Tricky Wiring
A tandem breaker allows to separate circuits to be installed in the space of one normal breaker.
No. The vast majority of tandem breakers only attach to one bus. You need a breaker that attaches to two buses to get 240v. I know of only two brands capable of this, and one is not that common.
You can't idiot-proof wiring. The proof is in the NEC. I just keeps getting bigger every 3 years in futile attempt to do just that.
Old 10-26-2012, 10:38 PM   #16
Every now and then poster
ohiohomedoctor's Avatar
Rewards Points: 3,544
Re: Tricky Wiring
Tandems have been taken overboard in my neck. I have seen some very busy 100amp services..
ohiohomedoctor is offline
Old 10-26-2012, 10:39 PM   #17
Trade: electrician
Rewards Points: 356
Re: Tricky Wiring
Oops i misread that you are actually doing the work...
Why not let an electrician do the electric work?
Old 10-26-2012, 10:40 PM   #18
Re: Tricky Wiring
Do you know how much those guys charge?
Old 10-26-2012, 10:45 PM   #19
Trade: electrician
Rewards Points: 356
Re: Tricky Wiring
Yes how dare they! I can go into home depot and the friendly guy will tell me everything i need to know it's not hard
Old 10-26-2012, 10:47 PM   #20
Re: Tricky Wiring
: laughing:
Hot trailer wiring harness MplsGC Electrical 5 04-29-2011 09:25 AM
Old house and electrical wiring ARTSBEST Electrical 3 09-25-2010 08:35 AM
Trailer power wiring Zayas_Const Tools & Equipment 2 03-21-2010 02:19 PM
Why Do Some States Still Insist On Piping Wiring? caseyleen Electrical 32 02-16-2010 08:54 PM
Disconnecting Wiring Question AlSmith Electrical 6 05-20-2009 09:06 AM
