Tresco Under Cabinet Lighting...
Old 12-18-2008, 10:04 AM   #1
MMC73
MMC73's Avatar
Trade: Painting & Tile
Not sure where to direct this question...as a painting and tile contractor I don't really know alot about electricity...except it hurts...lol.
I had Tresco under cabinet lighting installed in my house all of th lights with the exception of two work. As any enterprising contractor would I picked up a nifty tool to tell if there was power, there is...so why the heck wont the lights turn on under that one cabinet. I understand tha I am probably going to catch a lot of **** for the question just as you most likely would if you asked a stupid question about tile...lol...as long as the BS comes with some type of answer to point me in the right drection...I dont care. Thanks
MMC73 is offline
Old 12-18-2008, 12:29 PM   #2
Ummm wire guy?
SonoranShocker's Avatar
Trade: Professional Wire Slinger and Part Time Haji Wrangler...
Re: Tresco Under Cabinet Lighting...
First thing is with the main power on from the wall switch you can check to see if each fixture has its own individual switch, and flip them on/off.
Second, a lot of times the bulbs come pre installed, but bounce out of the socket during shipping. You can try checking the bulbs to make sure they are seated properly, and that they are in good working order to save yourself some money.
Third with the POWER OFF you can open the cover of the non working fixtures, and make sure the connections are good, and correct. (white to white, black to black etc.)
Thats pretty much as far as a DIYer should go in my book. After that call a licensed electrician.
Friendship is like peeing on yourself: everyone can see it, but only you get the warm feeling that it brings
SonoranShocker is offline
Old 12-18-2008, 05:58 PM   #3
MMC73
MMC73's Avatar
Tried the above...it would appear that the bulbs are not working...now I feel like an ass.
However I am going to pull the chick card and offer up a gracious thank you.
MMC73 is offline
Old 12-18-2008, 06:11 PM   #4
Ummm wire guy?
Lol, no worries. Glad I could help!
Old 12-19-2008, 12:22 AM   #5
TrblShooter's Avatar
Trade: Electrician
Heya MMC
Best way to check something like this..is turn it off...switch out a known working bulb from a different light, turn it on..if it works then just get some new bulbs
If not see other post lol
TrblShooter is offline
Old 12-19-2008, 07:05 PM   #6
MMC73
MMC73's Avatar
Originally Posted by TrblShooter View Post
Heya MMC
Well it would appear that "playing" electrician is easy..want to walk me threw the 200amp panel install and the RI I need to accomodate the third story I am planning on building if the rain ever stops??
MMC73 is offline
cabinet lighting alternatives?? trav007 Low Voltage 1 02-18-2008 11:23 AM
Under Cabinet Lighting (Dimmer) cambiumco Electrical 1 01-21-2008 11:32 AM
Under cabinet lighting steveprichard Electrical 10 12-12-2006 12:21 AM
Residential General Lighting Circuits toastermaker Electrical 11 02-26-2006 01:04 AM
