Tone Generators - Electrical - Contractor Talk
Tone Generators
Old 11-16-2017, 06:39 PM   #1
rselectric1's Avatar
Rewards Points: 688
Tone Generators
I'm in conduit land where we can usually trace wires easily and mechanically.
Because of that, I've really never found the need for a toner. In the last couple months I've had some service calls where I know having one would have been a huge help.
Because I would rarely use it, can you guys who deal mostly with NM recommend one in the under $400 range that you like?
Thanks!
Ron
rselectric1 is offline
Old 11-16-2017, 06:42 PM   #2
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 13,648
Re: Tone Generators
Progressive/Greenlee has always been my go to, ProsKit is excellent, Fluke Intellitone is excellent, JDS is a decent...only one I really hate is Paladin Tools which is now called Cable Check under the Greenlee name....real piece of junk.
No need to spend 400 bucks...
Sent from my Nexus 6P using Tapatalk
Inner10 is online now
The Following 2 Users Say Thank You to Inner10 For This Useful Post:
rselectric1 (11-16-2017), TxElectrician (11-17-2017)
Old 11-16-2017, 06:51 PM   #3
Rewards Points: 688
Re: Tone Generators
I don't do any low voltage, and in researching they seem to only show that part of how great their product performs. (I leave that fancy stuff to pros like you).
So difficult to get real advice from you tube and the internet in general EXCEPT here where I can trust the advice.
Old 11-16-2017, 06:55 PM   #4
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 2,603
Re: Tone Generators
Ron, I'm no connoisseur, but I don't think there's much advantage in spending more than $50-100 on one--unless you're looking for exotic functions. Mine cost around $50 several years ago, and it generally serves me pretty well. Too lazy to go out to the van and see what make/model it is.
There's a learning curve to using them. They're about three steps up from water-witching.
Tinstaafl is online now
Old 11-16-2017, 06:59 PM   #5
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 10,854
Re: Tone Generators
Greenlee 508S for me. You can find them used at a fairly good price.
Due to circumstances beyond my control, I am here.
480sparky is online now
The Following User Says Thank You to 480sparky For This Useful Post:
Old 11-16-2017, 08:32 PM   #6
tjbnwi's Avatar
Rewards Points: 4,890
Re: Tone Generators
I have this one. Use it on EMT often. Works very well. If you want to try before you buy let me know.
http://www.techtoolsupply.com/Produc...YaAtFBEALw_wcB
tjbnwi is online now
Old 11-16-2017, 08:39 PM   #7
480sparky's Avatar
Re: Tone Generators
Tone sets made for telecom usually don't last long tracing down line voltage wiring. All it takes is one, "Oops.... I guess it was hot...." and you've got a paperweight.
Old 11-16-2017, 08:48 PM   #8
tjbnwi's Avatar
Re: Tone Generators
Can't fix stupid.
I've had mine 16-17 years.
Old 11-16-2017, 09:23 PM   #9
Rewards Points: 688
Re: Tone Generators
Thanks Tom, me likey this one! Seems just right for me but I am anal just like electrician personalities need to be and will see what others suggest. So far this is the winner for my situation.
Old 11-16-2017, 10:12 PM   #10
tjbnwi's Avatar
Re: Tone Generators
I'd get one of these if it worked with the iPhone. Nice to be able to see what you're following.
https://walabot.com/diy
hdavis (11-17-2017)
Old 11-16-2017, 10:45 PM   #11
480sparky's Avatar
Re: Tone Generators
Can't fix stupid........
Sure you can! Just buy one made for line voltage.
Old 11-16-2017, 11:06 PM   #12
tjbnwi's Avatar
Re: Tone Generators
Not possible.
That's circumventing stupid.
Old 11-17-2017, 07:57 AM   #13
Inner10's Avatar
Re: Tone Generators
The progressive can take a quick flash....I can say from experience.
Old 11-17-2017, 10:20 AM   #14
hdavis's Avatar
Rewards Points: 2,905
Re: Tone Generators
One of those would have saved me a lot of hours and repairs on remodels over the years. No more guessing and hoping.
hdavis is online now
Old 11-17-2017, 09:55 PM   #15
Xtrememtnbiker's Avatar
Trade: General Remodeling
Rewards Points: 1,102
Re: Tone Generators
I've used this one in romex land quite a few times with good success.
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
One job was figuring why a receptacle in a dining room built in bar area didn't work in a house that was about 10 years old. Pull the coverplate and hot and neutral are reversed. Go out and check the panel box and all breakers are on.
Get out the toner and trace the wires to a junction box in the kitchen island. I took off the cover plate and found a hot and neutral that were capped off. Switched the wiring on the receptacle to correct, connected the wires in the junction box, and then the receptacle worked.
I guess somehow the electrician who did the trim out figured that if he disconnected that particular wire in the junction box the breaker would stop tripping and that was his solution.
Xtrememtnbiker is offline
Old 11-17-2017, 10:10 PM   #16
480sparky's Avatar
Re: Tone Generators
Not possible.
It's possible. But you want to argue semantics.
Old 11-17-2017, 10:37 PM   #17
tjbnwi's Avatar
Re: Tone Generators
Sure...
Old 11-18-2017, 01:52 PM   #18
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Builder/GC
Rewards Points: 602
Re: Tone Generators
Or you could get one for live wires......
https://www.amazon.com/Zircon-Breake...breaker+finder
And a toner for disconnected circuits.......
https://www.amazon.com/Greenlee-701K...nlee+toner+kit
By the way, these are the 2 that I have and use.
Delta
rselectric1 (11-18-2017)
Are generators only a rural concern? Cricket General Discussion 33 08-25-2014 07:24 PM
Tone and probe fun TWX Low Voltage 19 09-17-2012 11:12 PM
Portable jobsite generators Aztec Tools & Equipment 31 01-22-2012 02:22 PM
24V test probe with audible tone gastek HVAC 4 04-10-2011 07:38 AM
Two Tone Paint, How Much To Charge? A. Spruce Painting & Finish Work 7 12-14-2010 12:12 PM
