Tip
Old 01-30-2008, 08:26 AM   #1
sckeeth's Avatar
Trade: Electrical
Tip
Does anyone remember the tip where the the guy was changing a single gang mud ring to a 2 gang in a finished wall. He would screw the 2 gang face to face with the single and cut the drywall. If anyone knows where it is or somehow saved it could you please post that here. I would really like to see that again. I tried to search for it but could not find it.
Thanks
sckeeth is offline
Old 01-30-2008, 05:00 PM   #2
220/221's Avatar
Trade: electrician Phoenix AZ
Re: Tip
I don't see how you could screw it but you can certainly hold it up, eyeball it and mark it with a pencil easy enough.
Just because it's within code doesn't make it safe.
Just because it's against code doesn't make it unsafe.
220/221 is offline
Old 01-30-2008, 11:25 PM   #3
heavyduty73's Avatar
Trade: electrical
Re: Tip
it's been awhile but what we did was line up the slots on the two gang mud ring with the device holes in the single gang.the we traced around the outer edge of the two gang if wall paper we cut the paper first with a razor knife.then carefully cut the sheet rock with a jab saw. then wiggled out the old plate.
heavyduty73 is offline
Old 01-30-2008, 11:38 PM   #4
Tiger's Avatar
Trade: Electrical Contractor
Re: Tip
I've never used a roto-zip, but it seems like you could drill the 6-32 holes out on a flat single gang mudring just a bit, screw it to the existing single gang mudring & zip around the flat one for a perfect cut to install the double gang mudring. Personally, I use a sharp knife & cut them out in a few minutes.
Tiger is offline
Old 01-30-2008, 11:42 PM   #5
Fentoozler
Celtic's Avatar
Re: Tip
Personally...I'd hit that old single gang box with with a sawzall....grab a 2-gang box and cut it in....and be done with it.
Celtic is offline
Old 01-31-2008, 09:31 AM   #6
sckeeth's Avatar
Trade: Electrical
Re: Tip
celtic- it's already a two gang box.
sckeeth is offline
Old 01-31-2008, 10:54 AM   #7
Fentoozler
Celtic's Avatar
Re: Tip
So use a rotozip and trace the outline of the 4S box....you'll need to hit the 8/32 screws to secure the ring anyway.
Celtic is offline
Old 01-31-2008, 11:08 AM   #8
gregj's Avatar
Re: Tip
A rocker would just stab a rotozip in, whip it around the box and sneak away leaving the damaged wires for the electrician to deal with........or so I've heard. LOL
gregj is offline
Old 01-31-2008, 11:32 AM   #10
Fentoozler
Celtic's Avatar
Re: Tip
That is precisely why I have my own rotozip ~ leave the rockers out of the equation.
Celtic is offline
Old 01-31-2008, 03:50 PM   #11
220/221's Avatar
Re: Tip
Duh....just screw long 6-32's thru a single gang ring into the existing ring and roto zip around it.
Seems easier and cleaner just to eyeballe it and use a saw/knife
220/221 is offline
Old 01-31-2008, 05:30 PM   #13
Patrick's Avatar
Re: Tip
Originally Posted by Magnettica View Post
Oh that ole gag!
I thought that was only for fishing wires?
Originally Posted by Celtic
Like I said...I'm sure you are very good at what you do ~ whatever that is and where ever it happens.
Patrick is offline
Old 01-31-2008, 05:49 PM   #14
dkillianjr's Avatar
Re: Tip
No, this is for fishing wires!
dkillianjr is offline
