View Poll Results: will it leak?
yes 1 12.50%
no 6 75.00%
I don't know 1 12.50%
Voters: 8. You may not vote on this poll
Timer... Solenoid... Leak Through Current?
Old 04-24-2007, 09:16 AM   #1
Liquid Force's Avatar
Trade: Electric
If I have a solid state timer with a leak through current of 1 milliamp in the off setting, and a solenoid rated at 4 VA, is that enough to do anything to the solenoid? activate it in anywy? if I'm doing my math right, at 120v, that's about .12 of a volt amp, so 1/33rd or so of full power. If this solenoid is operting a pressurised hydraulic valve, is it enough to cause a leak?
Liquid Force is offline
Old 04-24-2007, 06:03 PM   #2
jbwhite's Avatar
Trade: Electrician
Re: Timer... Solenoid... Leak Through Current?
A leak in the valve? The valve will either be open or closed. Not something in between. Untill there is enough current to overcome the spring the valve will stay closed.
jbwhite is offline
Old 04-28-2007, 10:41 PM   #3
MSSI's Avatar
Trade: Electrician
NO.
MSSI is offline
Old 04-29-2007, 11:10 AM   #4
pala4058's Avatar
Trade: Landscape and Irrigation Contractor
If you have a fluid leak (constant), you may want to look at the diaphragm , gaskets or seals in the valve. Also check for rust or sediment inside the solenoid that may be hindering normal operation
pala4058 is offline
Old 04-29-2007, 05:45 PM   #5
DGFVT
CE1's Avatar
Trade: Electrical
No it will not. There will not be enough energy in the coil to move the pistion in the soleniod. If the piston in the solenoid does not move, the hydraulic valve will not shift. Does this have to do with theory or is there a hidden practical reason for the question?
Inquiring minds want to know.
Carry On!
CE1 is offline
Need help with a shocking outside waterspout Badoish Electrical 23 12-27-2008 04:18 PM
Gas Line - Can't Find The Leak jman116 Plumbing 27 08-19-2007 11:19 AM
Outdoor parking lot light timer question... UnderCaution Electrical 19 01-13-2007 12:33 PM
Current Square Price quasike Roofing 44 08-01-2006 07:21 PM
Leak in Ruud air handler in attic Geeteex HVAC 1 03-17-2006 08:07 PM
