Thermostat To Shut Off A Light. - Electrical - Contractor Talk
Old 12-29-2008, 11:39 AM   #1
Vrooman's Avatar
Trade: Builder, renovator
Rewards Points: 75
I just built a hot box to keep glues and caulking warm and to charge batteries. I hooked up a 300w light bulb in there but it gets too hot in there now..I want to wire up a thermostat to shut off the light when it gets to 15*C.
I think this would be safer than having a smaller wattage bulb running constantly, and that wouldnt let me control the temperature inside the box when we have wild temperature swings outside
Just wondering what the best way to do this is, Does any one have diagrams of something similar to this? Could you some how use a household thermostat?
Thanks guys
Vrooman is offline
Old 12-29-2008, 11:47 AM   #2
Steve
OCRS's Avatar
Re: Thermostat To Shut Off A Light.
some ideas here http://www.contractortalk.com/f40/wi...ube-van-27421/
OCRS is offline
Old 12-29-2008, 12:01 PM   #3
Vrooman's Avatar
Rewards Points: 75
Thanks for the link, Dont really want to take anything home at night, I would rather pull up to the job, plug the box in and it stays there locked until the house is built...It is a 4'x2'x2' box and its HEAVY. I need it to have a heat source running all day since all my chargers and batteries will be in there (and my lunch).
All I would like help with is wiring a thermostat to shut off a light. No solar chargers, propane, or any other heat source, just a simple light bulb.
Thanks!
Vrooman is offline
Old 12-29-2008, 01:40 PM   #4
Electrical Contractor
wirenut1110's Avatar
Trade: Electrical
Rewards Points: 25
You can just use a single pole line voltage thermostat (used for baseboard heaters) I've also seen one at HD that you just plug and play. Just google line voltage thermostat.
wirenut1110 is offline
Old 12-29-2008, 02:20 PM   #5
Tech Geek
WarriorWithWood's Avatar
Trade: Remodeling Guru
Rewards Points: 1,342
How about this or this or adapting a jamb switch relay with a simple 2 wire thermostat here
-Dennis
WarriorWithWood is offline
Old 12-29-2008, 02:22 PM   #6
FENCETECHS's Avatar
Trade: Decks, Barns, Stables, Fences,Outdoor Kitchens
I have a solution, go to ither a poltry equipment or pig farm supplier, and purchase a thermostat that will cut on and off at the temp you select, I have one in my pump house
Thanks guys
FENCETECHS is offline
Old 12-29-2008, 02:39 PM   #7
Handle It!
MALCO.New.York's Avatar
Rewards Points: 2,000
This is what you desire:
http://www.eheat.com/catalog/images/...PSP300_big.jpg
Or..................
This is what I use for a different cause:
http://www.midwesthydroponics.com/pr...scat_30158.jpg
Ultimate Wisdom---------
MALCO.New.York is offline
Old 12-29-2008, 06:28 PM   #8
Vrooman's Avatar
Rewards Points: 75
The plug in thermostat is perfect..going to check HD for it, thanks
Vrooman is offline
Old 12-29-2008, 07:05 PM   #9
Ink Slinger
Timo's Avatar
Trade: Retired Builder. Now graphics vendor to the trades
Rewards Points: 150
Thermo-cube is the brand I use.
Timo is offline
Old 12-30-2008, 10:20 AM   #10
boman47k's Avatar
Rewards Points: 2,006
I thought the same thing. Can be placed inside the container and activate when temp set is reached inside the container.
boman47k is offline
Old 12-30-2008, 12:14 PM   #11
mics_54's Avatar
Trade: contractor
I use Thermo-Cube. They are available in several on-off ranges. They seem to work well and I havent had any failures yet.
mics_54 is offline
Old 12-30-2008, 06:31 PM   #12
Steve
BACKWOODS's Avatar
Trade: Remodeling and Custom Cabinets
Rewards Points: 256
I was killing time in HD today and saw a thermostat to control attic power vents, $24 Adjustable temp knob.
BACKWOODS is offline
Old 12-30-2008, 07:22 PM   #13
mdshunk's Avatar
Rewards Points: 2,002
That's a cooling stat. Not a heating stat. That one makes on temperature rise. You need one that makes on temperature fall. The cord stats pictured above that they sell for the torpedo heaters work great for most any application.
mdshunk is offline
Old 12-30-2008, 08:23 PM   #14
Steve
BACKWOODS's Avatar
Rewards Points: 256
Thanks for setting me straight, I got close to being error free in 2008 and screwed it up in the last few hours! I will try harder next year
Old 12-31-2008, 05:44 PM   #15
Vrooman's Avatar
Rewards Points: 75
I bought a plug in thermostat at Canadian Tire today for $30. Does heating or cooling.
Hooked it up and works great, the box is outside ride now, -25*C out there, inside the box its a toasty +20. and the light seems to only run approx 50% of the time with a 300w bulb.
I also put a power bar in there for all the chargers.
Thanks for the help!
Vrooman is offline
Old 01-01-2009, 03:25 AM   #16
acrwc10's Avatar
Trade: Electrical contractor/General contractor/ ICC certified electrical inspector
Rewards Points: 150
now you just need to insulate the box for heat loss. Maybe you need an old fridge not a job box, just leave the appliance bulb in it on all the time.
acrwc10 is offline
Old 01-02-2009, 08:41 AM   #17
boman47k's Avatar
Disconnect the door switch that controls the light, or you will be defeating the purpose. Aren't those bulbs like only 15 watts? How much heat can that give off?
boman47k is offline
Old 01-02-2009, 04:17 PM   #18
kenny h's Avatar
Trade: electrical contractor
use an electric heat t stat as the switch it will work as a switch and your t stat
kenny h is offline
Old 01-02-2009, 07:44 PM   #19
Vrooman's Avatar
Rewards Points: 75
The box is 3/4 spruce plywood with 2" of extruded PS inside and on the lid, and protecting the foam is cheap paneling.
The 300w bulb heats the 16 cu ft quite easily
Vrooman is offline
Old 01-02-2009, 10:35 PM   #20
acrwc10's Avatar
Rewards Points: 150
Sounds like you could cook in it, if the T-stat is set high enough.
acrwc10 is offline
How many forum members to change a lightbulb? Al Truistic Off Topic (Non Trade) 48 11-09-2008 01:46 AM
Single pole vs. double pole thermostat dforeid Electrical 2 10-23-2008 09:42 PM
2 circuits controling a light TNRocks Electrical 4 01-28-2008 09:22 PM
How many members of CT does it take to change a light bulb? Bill Off Topic (Non Trade) 19 01-05-2008 01:13 PM
Feed back Please ,water heater Thermostat tzzzz216 Plumbing 4 11-11-2006 02:42 PM
