Theory
Old 03-05-2006, 08:57 PM   #1
49FRANKS's Avatar
Trade: ELECTRICAL
Theory
What Does Putting A Ground Fault Do To A Two Wire Circiut
How Does It Make Putting Three Prong Outlets Ok
I Have An Idea But Want To See What You Theory Guys Know
49FRANKS is offline
Old 03-05-2006, 11:30 PM   #2
Electrical Contractor
Speedy Petey's Avatar
Trade: Electrical
Re: Theory
As you probably know, a GFI does not need a ground to work properly.
By protecting a circuit with a GFI you get the benefits of the GFI, meaning the monitoring of the circuit between line and neutral. If there is an imbalance the GFI will trip. The imbalance has to go to ground eventually.
So a circuit without the protection of a grounding conductor still has the protection of opening a circuit if there is a fault to ground.
Speedy Petey is offline
Old 03-06-2006, 02:04 PM   #3
49FRANKS's Avatar
Trade: ELECTRICAL
Re: Theory
THANKS DUDE
49FRANKS is offline
Grumpy in action Grumpy General Discussion 66 09-08-2006 05:39 PM
Just finished E-Myth Revisited. Have a question RE: Prototyping Melissa Business 45 07-10-2006 12:59 PM
Testing the theory Mike Finley Electrical 21 05-23-2006 07:35 PM
Conspiracy Theory Mike Finley Off Topic (Non Trade) 15 01-30-2006 11:11 PM
AC Theory/ Unbalanced Current Josh White Electrical 7 07-20-2005 12:32 AM
