Testing A Motor
Old 11-01-2007, 06:55 PM   #1
Electrical Apprentice
darren's Avatar
Trade: Electrical
Testing A Motor
So i get a call at work today and the wife says that the dryer stopped working. So when I got home I ripped it apart and tested the resistance of the motor. It is reading O.L., which in know means there is no resistance.
Is this is a sign of a crapped out motor, its been a while since i have done any work on a motor.
Thanks
darren is offline
Old 11-01-2007, 07:35 PM   #2
joasis's Avatar
Re: Testing A Motor
No reading indicates no continuity, or in other words, an open in the field....in other words, junk it.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Serving Oklahoma Statewide
joasis is offline
Old 11-01-2007, 08:01 PM   #3
Fentoozler
Celtic's Avatar
Re: Testing A Motor
Before you junk it....check the dryer vent - is it full of lint?
There should be a little replaceable hi temp. cutout on the back of the dryer...if/when it goes....the dryer will spin, but not make heat.
I bring this up because last year at this time I got the same call....not from your wife, but mine
I found the problem by checking a few appliance websites:
http://www.repairclinic.com/
http://fixitnow.com/
A few others...
EDIT:
You said the MOTOR was fubarred?
Celtic is offline
Old 11-01-2007, 08:10 PM   #4
darren's Avatar
Trade: Electrical
Re: Testing A Motor
Thanks that is what i thought.
Nothing happens when you hit the start button, hince why i suspected the motor.
I opened up the back of it and can't beleived my house has not burned down yet with all the lent in there, guess i will have to add to my yearly chore list.
darren is offline
Old 11-01-2007, 08:12 PM   #5
Fentoozler
Celtic's Avatar
Re: Testing A Motor
At least my post wasn't an entire waste
Celtic is offline
Old 11-01-2007, 11:43 PM   #6
Union Electrician
Sparky Joe's Avatar
Trade: Inside Wireman
Re: Testing A Motor
Not a total waste, I was just defeated by the dishwasher.
It seems the 6 accessible screws do not remove the spinny thing on top of the water sucker in-er thing.
So I'll do my research with the sites posted and dive in head first tommorrow, thanks
Sparky Joe is offline
Old 11-02-2007, 12:02 AM   #7
mickeyco's Avatar
Trade: Squirrel Handler
Re: Testing A Motor
On the dishwasher thing, if you or anyone else has a GE dishwasher there is a recall for starting fires (I have one of the recalled units), they'll fix it for free or give you a coupon for money off the purchase of a new one. I think the time is near for exercising your options before the offer expires.
On May 16, 2007, the U.S. Consumer Product Safety Commission (CPSC) and the General Electric Company (GE) announced a recall of 2.5 million GE built-in dishwashers manufactured from September 1997 to December 2001. Submit the information below or call the GE Recall Hotline to determine if your dishwasher is included in the recall.
http://www.geappliances.com/products/recall/dw07/
mickeyco is offline
Old 11-02-2007, 12:33 AM   #8
MFWIC
Tmrrptr's Avatar
Trade: house painter
Re: Testing A Motor
Darren,
Plumber I know had about 1/3 of his house burn from a dryer vent problem.
Center of house laundry room, long vent run, habit of using very much smelly stinky fabric softener stuff that combined w lint and torched the house.
Check more often than once a year!
They actually have guys that clean vents professionally...
r
Tmrrptr is offline
Old 11-02-2007, 12:44 AM   #9
Teetorbilt's Avatar
Re: Testing A Motor
Tm, was that plastic vent hose involved?
Albert Einstein
Teetorbilt is offline
Old 11-03-2007, 10:30 AM   #10
Baltimore Electrician
JohnJ0906's Avatar
Trade: Electrician
Re: Testing A Motor
Hey! Easy on all those technical terms!
John from Baltimore
"One Day at a Time"
All replies based on the 2008 NEC
Originally Posted by celtic
Deny Everything, Admit Nothing, Demand Proof
JohnJ0906 is offline
Old 11-03-2007, 12:08 PM   #11
BigJon3475's Avatar
Trade: HVAC/R
Re: Testing A Motor
If at all possible replace with straight piping not flex......Flex no matter what it is made of is horrible for trapping lint in between the metal rings (frame) of the flex. Once it's there it collects much faster than when it's brand new. Straight pipe has flat surfaces and takes much longer to gather lint up.....make sure you don't use any sort of screws to attach it anywhere...for obvious reasons.
BigJon3475 is offline
Old 11-03-2007, 12:39 PM   #12
mdshunk's Avatar
Re: Testing A Motor
That's actually code. No penetrating fasteners, and a 25' max duct run. Each ell counts as 5 feet.
mdshunk is offline
Old 11-03-2007, 04:41 PM   #13
BigJon3475's Avatar
Trade: HVAC/R
Re: Testing A Motor
I don't deal with dryer vents all that often......That was just what I have noticed with flex vents plastic/metal....Good to know that it's code though if I have to deal with anymore now I know thanks.
Old 11-08-2007, 11:01 AM   #14
boman47k's Avatar
Re: Testing A Motor
If the windings show no continuity, the stats would have no bearing in this situation.
boman47k is offline
testing motor circuits mark999 Electrical 7 11-09-2007 12:11 AM
Leeson table saw motor Milhaus Electrical 6 10-14-2007 08:24 PM
New Fan Motor Installation jerome8283 HVAC 13 09-20-2006 08:18 PM
Motor Capacitor Leo G Electrical 4 09-12-2006 10:48 AM
Slow motor jbfan Electrical 4 06-29-2006 09:12 PM
