Testing Exterior 175 Mercury Vapor Lamp - Electrical - Contractor Talk
Old 04-08-2012, 02:34 PM   #1
artinall's Avatar
Trade: Repairs & Finishing
Rewards Points: 1,916
Couple months ago the lens cover fell off this fixture, pulling down through the hole pair. Ever since it was left exposed.
Now that a replacement came in, and was attached, the lamp doesn't light.
Pulled off the new lens and tested the black power leads, all have power (marked) . I attempted to tape off the top light sensor. Can test again when the others light at nightfall to be certain.
How to determine if the problem is the light sensor or the ballast of even the light socket due to exposure to the elements? If its the ballast, it's cooked and these are discontinued - which match the other ones on the barn. And popular as it is, I'm not going to convert the lamp to another type.
Is the white socket lead routed directly from the light sensor or the ballast? I'm trying to minimize time spent on the extension ladder with neck craned straight upward. A tad awkward.
- Was hoping that with all the vibration from the lens cover, it was as simple as a loose connection. That's about as much as I can clarify that dark recess.
artinall is online now
Old 04-08-2012, 03:49 PM   #2
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 10,780
Re: Testing Exterior 175 Mercury Vapor Lamp
New fixtures are what?.... Fifty bucks?
Why is there not a Flat Mars Society?.
480sparky is online now
Old 04-08-2012, 05:00 PM   #3
artinall's Avatar
Regent says that they quite making these 175MV according to law. This is what matches our others.
The Following User Says Thank You to artinall For This Useful Post:
MALCO.New.York (04-18-2012)
Old 04-15-2012, 06:45 AM   #4
mrmike's Avatar
Trade: Electrical & Carpentry
I have seen HPS ballast/lights run "forever" without the lens. Having worked on them a lot in industry, I don't know what you mean by "pulling down the hole pair" ?.
If the ballast cooked you would know it by the smell & looks. As for the lamp socket-it is wired from the secondary of the ballast.
As this post is about a week old what did you find????
mrmike is offline
Old 04-15-2012, 07:48 AM   #5
artinall's Avatar
Did test the wires feeding in and found a failure at the light sensor - power goes in but it doesn't come out. So I pulled the sensor and the three prongs are rust laden, with the foam seal broken.
Maybe all that movement shook it loose.
Looks like a new lamp.
Old 04-17-2012, 09:49 PM   #6
SemiRetiredEL's Avatar
Trade: Electrial Contractor (master)
Rewards Points: 75
what you said
SemiRetiredEL is offline
Old 04-18-2012, 07:50 AM   #7
artinall's Avatar
But here again its just not one, probably three. Someone else will have to do it - no time on my end.
- Thanks for the posts.
EPA Backs Off Lab Testing for Lead greg24k General Discussion 3 09-28-2011 06:17 AM
EPA Drops Requirement for Third Party Testing on Lead Paint Removal Grumpy Lead RRP Discussion 2 07-26-2011 09:27 PM
Who makes a better remoldeling Double Hung ? Anderson, Mercury ? CarpTedII Windows, Siding and Doors 4 06-19-2011 09:27 PM
Independent observations and materials testing rblank Commercial Construction 8 12-16-2010 11:40 AM
Drug testing. flashheatingand Off Topic (Non Trade) 151 01-03-2009 10:15 AM
