Trade: Floorist
Temporary 220
The big machine used for sanding wood floors runs on 220 volts. The cord is a 10/3 cable. Some homes have no 220-volt outlet, though there may be enough power available in the box.
What might I expect to pay an electrician to do an in-box hook-up or to add a 220-volt outlet next to the main panel. Is there a 'temporary' option, something I could be able to learn/ utilize on my own, for future jobs? Certainly there are variables possible in this scenario so I am asking that you assume we have optimal access, etc. Thanks for your professional opinions.
• • • Greatness is a result of focused, deliberate practice • • • |
And I do electrical, too!
Re: Temporary 220
If you're a typical flooring installer, you'll forgo calling an electrician to properly wire something for you and just put alligator clips on your cord and clip right onto the main lugs of the panel.
Of course, you didn't hear that from me.
Site : the area or exact plot of ground on which anything is, has been, or is to be located. Sight : The power or faculty of seeing; perception of objects by use of the eyes; vision. Cite : To mention in support, proof, or confirmation; refer to as an example. |
Handle It!
Re: Temporary 220
WORKS well!!!!!!!!!!!!!!
If ya do not fudge it up!!!!! Are you feelin' "Lucky" today????? Then.............. Go for it!!!!
Chief outhouse engineer
Trade: mason
Re: Temporary 220
Electric dryer is 220. Get an adapter for your cord. Sometimes the garage will have a 220 crows foot.
Last option is a 50 amp 220 breaker that is put in the box on a temperary basis. Should be installed by an electrician. I list my electrical needs in my bid so it is clear from the get go that I need some special electrical options.
D K & Sons The maintenance schedule for brick 1. Stand back and say "man that looks nice!" 2. Repeat as often as needed. |
Master Electrician
Trade: Electrical
Re: Temporary 220
Hell 480. The mexicans at our job yesterday just bunched up the end of wire and put them in the allen hole opening of the main lugs then wrapped the ground around some random bare copper. I took a photo but I cant download. I'll try later
#6 | |
Trade: Electrical
Re: Temporary 220Quote:
So far, the only usefull response to the OP |
| The Following User Says Thank You to TxElectrician For This Useful Post: | TopFloor (10-08-2009) |
Trade: GC/Remodeling
Re: Temporary 220
ditto that...also might have 220 for a window unit somewhere.
When I started out, I used to drag my big 220 compressor around. I had a long cord made to fit a dryer, and on the 'outside' end, a box with my 220 and a pair of 110 outlets for the saws/radio...
-Steve "The most beautiful thing we can experience is the mysterious. It is the source of all true art and science." ~ Albert Einstein |
Trade: Floorist
Re: Temporary 220
Thanks Dakzaag. How much should I reasonably expect to pay to have this done? How much time would it take to complete the work, under optimal conditions?
Trade: Floorist
Re: Temporary 220
Thanks TimelessQuality. I appreciate your input.
Did you ever have a situation where there was no dryer outlet? Or, what might you have done if there was no outlet available?
Trade: mason
Re: Temporary 220
Top Floor,
Sorry, I'm a mason, not an eletrician. Call around, and ask while your on the site if a sparky happens to be there. If you get a chance when your looking at the job for the first time, just look at the control box. Any big amp connections are going to jump out at you and then you know if you have options, or if your gonna need special wiring. Again, if you note it up front, usually a sparky is on site sometime before you and if it is in his bid, cost wise it will not be too bad. (word the contract properly and the owner will pay for it, not you.) I was on a job several weeks ago and the power went out to the whole site. No idea what happened, I didn't need the juice, but the dry wall crew was inside going at it like they were killing snakes. No power, no lights no work. They had a portable in the van and were up and running in about 10 minutes. I was impressed, they were definately prepared for this and didn't skip a beat. Point is you might want to be set up the same way, so you don't lose work because of the hassle or some sparky forgetting he was to supply you with the needed power. I have a gen set, but don't normally have it along unless I know I will need it. Its extra for using it on a remote site and I charge enough that I don't need it very often.
D K & Sons The maintenance schedule for brick 1. Stand back and say "man that looks nice!" 2. Repeat as often as needed. Last edited by dakzaag; 10-08-2009 at 01:19 PM. Reason: can't type |
| The Following User Says Thank You to dakzaag For This Useful Post: | TopFloor (10-23-2009) |
#1 stunner
Re: Temporary 220
Do what all the other Mexicans do, cut the plug off your sander, strip it back, and then jam it in the dryer outlet.
#12 | |
Dryer outlet? WHAT dryer outlet?!?!
We don't need no steekeeng dryer outlet! ![]()
| The Following User Says Thank You to 480sparky For This Useful Post: | TopFloor (10-09-2009) |
#13 | |
Trade: Floorist
![]() Trade: student again
Re: Temporary 220
What is the amp requirement? You didn't hear this from me, but you could find two different outlets on separate poles, run two extension cords and use the hots from both as long as you don't exceed 15 or 20A, depending on the amperage of the outlet being fed from.
#15 | |
Trade: Floorist
• • • Greatness is a result of focused, deliberate practice • • • Last edited by TopFloor; 10-23-2009 at 02:25 AM. |
#16 | |
#1 stunner
Re: Temporary 220
I say if your checking out a job. First stop is the utility room to see if dryer has 220 plug. If it does your cooking. My dryer has the fat hardcore 220
| The Following User Says Thank You to 747 For This Useful Post: | TopFloor (10-23-2009) |
#18 | |
You'll have 208v if it's a 208Y/120v fed building. It's safe if you know what you're doing. It looks stupid No, it's not code compliant Yes, my drawing looks stupid. |
#19 | |
#20 | |
Trade: Floorist
| Tags |
electrical outlet 220 ![]() |
| Temporary Operator Needed | SDG | Help Wanted or Looking For Work | 2 | 07-13-2009 11:09 PM |
| Temporary Gutter Repair (Liquid Roof?) | fuzzy1 | Roofing | 3 | 11-03-2008 06:03 PM |
| Temporary Heat | Jason Whipple | Construction | 24 | 11-03-2008 10:26 AM |
| What the heck temporary light hackjob | Electric_Light | Electrical Picture Post | 3 | 04-06-2008 06:05 PM |
| temporary help | tnmtn | Excavation & Site Work | 0 | 04-07-2007 01:05 PM |
