Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Electrical
Old 02-02-2008, 07:28 PM   #1
mickeyco's Avatar
Trade: Squirrel Handler
Taping outlets/switches
I was watching Ask This Old House and they had an electrician replacing a light switch and she wrapped the switch with electrical tape to cover the contacts. I remember seeing posts here that that was a sure fir way to spot a DIY'er work. I don't if it was a metal or plastic JB but I see plenty of electricians do it out here (we only have metal boxes). So what's the deal, this a regional thing, not necessary or just a crazy woman electrician?
mickeyco is offline   Reply With Quote
Old 02-02-2008, 07:31 PM   #2
Remodeling Professionals
Wimmen shouldn't be messing with electricity, other than to dry their hair....and cook.
http://www.buildenterprises.com
buildenterprise is offline   Reply With Quote
Old 02-02-2008, 07:42 PM   #3
mickeyco's Avatar
You're a brave and/or foolish man for making that statement.
Old 02-02-2008, 07:43 PM   #4
Licensed Electrician
knothole's Avatar
Trade: Licensed Electrictian
Never seen it done in my area, but what do I know.....
Follower of Jesus Christ
knothole is offline   Reply With Quote
Old 02-02-2008, 07:49 PM   #5
mdshunk's Avatar
Yes, I see that as a way to spot DIY work. There are a couple of times when I will wrap a switch or receptacle. 1) when I'm replacing a device hot, and the box is metal. Keeps me from accidentally tripping the breaker and/or embarrassing myself. 2) For temporary devices on a construction or remodel job, where the cover plates are omitted for the installation of the wall finish material.
mdshunk is offline   Reply With Quote
Old 02-02-2008, 07:54 PM   #6
Yea, I will tape them when I am working on a live circuit and a metal box.
Old 02-02-2008, 07:56 PM   #7
We had one electrician who
always did it on old work(steel boxes),
but as Md, said the trim was never going
back on while he was there.
Always before finish coat paint.
neolitic is offline   Reply With Quote
Old 02-02-2008, 08:00 PM   #8
nap
Trade: sparky
I have had it spec'd in the job spec's. It was stated as " devices (switches and recpetacles) will be wrapped with no less than two complete layers of electrical tape". This was a multimillion dollare hospital BTW so it was not a little nobody architect/engineering firm making odd requests.
If I am using cut-in (metal) boxes or masonry boxes; it is an absolute.
If there are multiple devices- again, it gets done
single devices in a 4 square box; usually not.
nap is offline   Reply With Quote
Old 02-02-2008, 08:13 PM   #9
7 card stud master
james8199's Avatar
Trade: electrician
I only do it working live as a couple of other guys have said. The company I work for though is kinda hell bent on it. The first job I did with them at this grocery store I was questioned as to why I wasn't taping any devices. I told him that I never did and he told me that it was code. I have never seen this anywhere in the code, unless it's a jurisdiction thing.
"Oh, you hate your job? Why didn't you say so? There's a support group for that. It's called EVERYBODY, and they meet at the bar."
-Drew Carey
james8199 is offline   Reply With Quote
Old 02-02-2008, 09:23 PM   #10
Trade: electrician Phoenix AZ
1. Metal cut in box+hot
2. Hot trim before drywallers/tapers are done.
3. Pre granite backsplash when I know the granite guys will be removing/replacing them.
Just because it's within code doesn't make it safe.
Just because it's against code doesn't make it unsafe.
220/221 is offline   Reply With Quote
Old 02-02-2008, 10:44 PM   #11
goose134's Avatar
Trade: Union Electrician
Man, I started to feel bad about taping my outlets, until I started seeing that people tape in metal boxes. That's all we have. So I tape devices.
goose134 is offline   Reply With Quote
Old 02-02-2008, 10:45 PM   #12
Trade: Licensed Electrician
Then I apprenticed for an awful lot of DIYers. Taping contacts on outlets and switches was Standard Operating Procedure with the Wichita IBEW guys I worked under, and with
Sportbilly is offline   Reply With Quote
Old 02-02-2008, 11:13 PM   #13
Fentoozler
Celtic's Avatar
Why would you tape an outlet/switch?
Celtic is offline   Reply With Quote
Old 02-02-2008, 11:30 PM   #14
The reasons I was given were
a: Less likely to contact box/wire in the event it was pulled apart
b: Less likely to contact fingers under same conditions
That's it, just something we always did.
If one were to ever service/test this outlet hot, might have made more sense to me, but as it was, never saw the need, unless one had bare copper ground wire in resi work?
Old 02-03-2008, 12:06 AM   #15
reveivl's Avatar
Trade: Renovations
Doing remodeling I am often dealing with hot circuits and often have to replace/repair/alter the finish surface, so I unscrew the receptacles, tape them and then tuck them into the box out of the way. This allows the installation of the new surface without damaging the receptacles/switches. It never occurred to me that this was in some way 'wrong'. It simply made sense at the time.
Other than 'being the mark of a DIY' is there something intrinsically wrong with this practice? Is there something dangerous about this practice? Is there any reason why someone shouldn't use this practice?
I'm curious why you would bring this up because to tape them in my line of work simply makes sense to this carpenter.
"Too much is always better than not enough"--J.R. "Bob" Dobbs
reveivl is offline   Reply With Quote
Old 02-03-2008, 12:43 AM   #16
Historic specialist
Trade: General B100 Utah
we do both...
I work with 2 different electricians that have very different backgrounds. One is mainly commercial and industrial, the other hammers through ugly historic renovations.
The industrial guy, Tapes every device.
The renovation guy, never seen him tape a device.
I think they are both right... I like leveling the device with the tape on it much better.
you mentioned the granite backsplashes, we have been using the adjustable depth boxes for years on those and it works great. You can leave it sticking out a couple inches to make it easy to manuever and then adjust it perfectly flush after install.
TD
www.EnoceanWireless.com
Wireless lighting control, without using batteries
Use the Discount Code "Contractor" if you'd like...
tdavis is offline   Reply With Quote
Old 02-03-2008, 12:46 AM   #17
Fentoozler
Celtic's Avatar
If the outlet were installed properly the first time....the tape would serve no purpose.
If the outlet needed some "attention" - why would you work it hot?
Old 02-03-2008, 12:57 AM   #18
I know I know, don't shoot the messenger lol
Old 02-03-2008, 02:49 AM   #19
Licensed Contractor
Magnettica's Avatar
Trade: Electrician
I always tape my switches and receptacles if they're in a metal box. The reason being is for the next guy who may need to get in there for troubleshooting or whatever. This way, the likelyhood of a ground fault happening is less likely.
Magnettica is offline   Reply With Quote
Old 02-03-2008, 07:58 AM   #20
Celtic's #1 Fan
Trade: electrical
i don't care so much whether a device is taped or not...it's when wirenuts are taped that I shake my head...
i have one building where the lighting is 480V, the circuits are run in #10 XHHW (job spec'd it) and the lighting has #16 SO cord...whomever installed these, and it's my guess it was the same apprentice that spliced all of them, did the following:
used a knife to strip approx. 1 inch of insulation off the end of each #10, and then stripped approx 1.5 inches off the SO cord...twisted them all together, and used a really cheap version of a red twister...this left approx 1/2" of exposed wire at each splice...so they taped every splice with incredibly cheap tape (not even 1700)...
oh...this is a Port Authority building...engineered to the hilt and installed by a closed shop...
mahlere is offline   Reply With Quote
Taping A House???????? Rrisky Drywall 3 01-10-2008 06:38 AM
soap in taping mud??? Rrisky Drywall 2 01-06-2008 10:08 AM
corner taping tools SHIRL Drywall 2 08-15-2007 02:34 PM
Automatic taping tools MagnumBI Drywall 1 02-02-2007 05:03 PM
Bubbles when taping over painted surface? theworx Drywall 19 08-19-2006 01:52 PM
