T-shoot Gfci Breaker
Old 10-18-2006, 07:25 AM   #1
hurricaneflyer's Avatar
Trade: electric
To eliminate mixed neutrals as the reason a gfci breaker would not set I thought I could turn off all other breakers in the panel. If the problem was mixed neutrals this would allow the gfci breaker to set.
My co-worker says this will not do anything to eliminate mixed neutrals as the problem
I have been searching but have not found the source of info for this t-shooting trick
I may have seen this on one of the forums but havent found the post.
I'd sttill like info for future reference a link to somthing i could print out would be great even if I am wrong I will show it to my co-worker so he will know I admit when I am wrong.
This particular instance we found a ground to neutral short in a receptacl outlet
hurricaneflyer is offline
Old 10-19-2006, 01:29 PM   #2
macmikeman's Avatar
Trade: Master Electrican, Electrical Contractor
Re: T-shoot Gfci Breaker
That is a good tip. And it should work equally well for the same problem with mixed up neutrals on afci protected circuits.
macmikeman is offline
Old 10-21-2006, 02:45 AM   #3
Trade: electric
macmikeman,
Thanks for the reply. Are you confirming this idea as correct or saying its a good idea IF its correct?
I am looking for confirmation that it is indeed accurate.
The three jurisdictions I mostly work in are not inforcing aNy AFCI protected circuits yet. Thats fine by me except I am falling behind learning to troubleshoot them when the time does come
Old 10-21-2006, 04:21 PM   #4
Philadelphia electrician
RobertWilber's Avatar
Trade: Electrical contractor
Absolutely eliminates problem of mixed neutrals
There will be only ONE hot, so there is no mixed neutral for GFI to contend with. Obviously, however, this will only work for tests. [only SEEMS to eliminate mixed neutral problem]
RobertWilber is offline
Old 11-12-2006, 07:38 PM   #5
Trade: electric
Thanks guys,
Old 11-13-2006, 08:16 PM   #6
Union Electrician
Sparky Joe's Avatar
Trade: Inside Wireman
Not sure if I'm understanding the question; you have a gfi breaker and forgot which romex it is? or the gfi receptacle won't reset because it's part of a multiwire cable?
either way a gfi needs power for the reset button to work
and if the bare ground is touching the neutral it will trip the gfi every time a load is put to it, multiple current paths and all
"t-shooting" trick, that's anew one for me, can someone explain what that means? Or even perhaps what this poor guys problem is?
Sparky Joe is offline
Old 11-14-2006, 07:16 AM   #7
Trade: electric
Joe,
We went on a service call. "a breaker will not set" was the reason given.
When we got there we discovered it was a gfci breaker that would not set. The breaker was labled as "outside receptacles, porch lights, underneath"
This was a huge two story house. We found 12 receptacles and two sets of lights not working . There was only the one breaker that would not set.
This was a rental house. I called to see if we could get any more info. Had thier maintenance people been out there changing out any receptacles or switches? Had any other trades been there working?
There was no answer to those questions so we were at square one.
My co-worker and I agreed to try to narrow down the possible causes before we started pulling devices and lights out for inspection.
We bypassed the gfci portion of the breaker and found the breaker would then set and everything worked. That eliminated a hard short as the problem. We hooked the gfci breaker back up properly.
I then started flipping off all the other breakers, thats when my co-worker asked me what I was doing that for. Our disscusion and disagreement started at that point and thats what prompted my post here.
t-shooting trick, method to help discover or eliminate a cause of a problem. Sorry for being too lazy at the time to type out trouble-shooting.
Old 11-14-2006, 06:41 PM   #8
Union Electrician
Sparky Joe's Avatar
Why not just do a continuity test between the ground and neutral from the panel when you had it all taken apart?
And for that matter check continuity between hot and neutral and ground rather than the 'hook it up and see if it explodes' method
Old 11-14-2006, 07:37 PM   #9
Trade: electric
Of course you are right Joe. My co-workers and I cant seem to stop playing the "I can name that tune in 3 notes" game, except we do it with troubleshooting. I know we should grow up, but I ain't holding my breath.
Old 11-14-2006, 07:45 PM   #10
mdshunk's Avatar
No, that 'hook it up and see if it explodes method' is accomplished by slapping the circuit conductor on the buss bar.
I had a co-worker once upon a time who found faults with such a test. Hold it on the buss bar and look for where the smoke is. Wacky dude...
mdshunk is offline
Old 11-14-2006, 08:56 PM   #11
Union Electrician
Sparky Joe's Avatar
[QUOTE=mdshunk;154705]No, that 'hook it up and see if it explodes method' is accomplished by slapping the circuit conductor on the buss bar. QUOTE]
Now that's even nuttier than you. "Birds of a feather" right.
We did something similar once; The sheetrockers had their Mexican music blaring while we needed to communicate during a wire pull. After asking them and turning it down for them several times, we finally went to the electrical room knowing what circuit their radio was plugged into, we pulled the neutral and slapped it against the bus of a different phase. It was real funny when we did it, but funnier watching them try to figure it out.
GFCI breaker seattle_sparky Electrical 24 01-25-2009 11:38 AM
GFCI breaker appears to be bad 72chevy4x4 Electrical 14 06-03-2008 12:11 PM
GFCI breaker RobertCDF Electrical 19 05-09-2007 06:56 PM
Breaker keeps popping DErnest Electrical 2 09-15-2006 06:30 PM
gfci breaker Browny Electrical 6 05-29-2006 07:45 AM
