Switching Lighting
Old 04-10-2006, 10:57 PM   #1
McElectric's Avatar
Trade: Electrical Contractor
Switching Lighting
I am wiring a bedroom that has 6 recessed cans. They are switched with two 3-ways. The home owner wants to be able to switch one on or off seperately. But he wants the 3-ways to still switch all 6. Is there a simple way to do this? I can't think of anything other than a relay???
McElectric is offline
Old 04-11-2006, 12:19 AM   #2
I'm just stirring the:
CGofMP's Avatar
Trade: .
Re: Switching Lighting
Tell him you are gonna have to install a small switch pannel like this one:
IBM Tss 360
Memorable Places - My little home on the web
Member of the White Knights Of Contractor Talk
CGofMP is offline
Old 04-11-2006, 07:08 AM   #3
Speedy Petey's Avatar
Trade: Electrical
What you(they) propose is contradictory. One switch will inherently override the other.
If you do all on the 3-ways, and an extra single pole for the one light the three ways will turn them all off. He will not be able to turn the single light on and off at will.
The opposite holds true if you reverse that.
I would just suggest two sets of 3-ways. One set for 5 lights, and the other set for the single.
It is a simple solution to a wierd request.
Speedy Petey is offline
Old 04-11-2006, 07:40 AM   #4
DGFVT
CE1's Avatar
Trade: Electrical
How about this:
Attachment 1952
The one light will be able to turn on-off by itself but the other 5 lights will turn on-off by the 3-way switches. The only problem would be that the one light would have to be on in order for the other 5 lights to turned on.
Note: This circuit probbly would drive an electrican that came after you in a few years CRAZY!
But as Speedy Petey suggested the two 3-way circuits might be better.
Your choice.
CE1 is offline
Old 04-11-2006, 08:02 AM   #5
Master Electrician
krthomp33's Avatar
Trade: Electrician
AH, yes, one of those things that makes you scratch your head and wonder, "WTF was the other guy doing?"
krthomp33 is offline
Old 04-11-2006, 08:59 AM   #6
DGFVT
CE1's Avatar
Trade: Electrical
It would work though.
CE1 is offline
Old 04-11-2006, 10:13 AM   #7
jbfan's Avatar
It would not work. With the single pole open. the 3 ways would not have any power. I don't think it can be done without some relays.
We are the people (our parents warned us about) (Jimmy Buffett)
jbfan is offline
Old 04-11-2006, 11:16 AM   #8
DGFVT
CE1's Avatar
Trade: Electrical
You are right it would not work for the poster!
I misread the post.
CE1 is offline
Old 04-14-2006, 04:44 PM   #9
mas2006's Avatar
Trade: Electrical engineering
Blonde says, "Doctor every part of my body I touch hurts."
Doctor says, "Your a natural blonde right? Your finger is sprained."
Sell them a home automation system, then the only limit to stupidity is their wallet.
mas2006 is offline
Old 04-17-2006, 04:18 PM   #10
RowdyRed94's Avatar
Trade: Residential custom home builder
Seems like you should be able to pull a 3- or 4-way switch off of one of the original three ways and use it to switch the single in such a way that flipping one of the original 3-ways only turns the single light on or off to match the others. Come on, guys. Someone here has a bigger brain than me and can work this out.
Clint - carpenter, coordinator, webmaster
RowdyRed94 is offline
Old 04-18-2006, 07:19 PM   #11
DGFVT
CE1's Avatar
Trade: Electrical
Yes there are other ways to do what the original poster wanted to do but in a practical way, no
Here is a little philosophy to think about and it does apply to the original post.
Occam's Razor
"When you have two competing theories which make exactly the same predictions, the one that is simpler is the better."
"If you have two theories which both explain the observed facts then you should use the simplest until more evidence comes along"
"The simplest explanation for some phenomenon is more likely to be accurate than more complicated explanations."
"If you have two equally likely solutions to a problem, pick the simplest."
"The explanation requiring the fewest assumptions is most likely to be correct."
. . .or in the only form that takes its own advice. . .
"Keep things simple!"
CE1 is offline
Old 04-18-2006, 10:32 PM   #12
LRG WoodCrafting
Leo G's Avatar
How about this? Add or remove as many switched circuits as you want, this one will let you switch five lights and then turn them all on and off with the three way.
Sawdust Follows Me Everywhere
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is offline
Area lighting for Pipe Guy mdshunk Electrical 5 01-26-2009 02:25 PM
Shop Lighting Leo G Electrical 19 10-13-2006 08:41 PM
Residential General Lighting Circuits toastermaker Electrical 11 02-26-2006 01:04 AM
Landscape Lighting NightScenes Landscaping 0 01-11-2006 06:58 PM
