Switched Receptacle- A Couple Of Questions
Old 02-08-2007, 11:52 PM   #1
ChuckEA's Avatar
Trade: handyman
Customer wants to make one of the existing wall receptacles in a bedroom switchable. Currently there is a 2 gang switch box in the room to control a ceiling fan/light but only the fan switch is being used. The wall receptacles and the ceiling fan are on separate 15A circuits. As I see it, there are 2 options to do this but I'm not sure which, if any, is legal or preferrable: 1. Run the switched receptacle from the existing receptacle circuit. or 2. Run the switched receptacle from the ceiling fan/light circuit. Either way, it would mean having multiple circuits in a junction box (either the switch box or the receptacle box)
Question 1 - Is it ok to have multiple circuits within the same junction box?
Question 2 - If the answer to question 1 is yes, which of the 2 options would be the preferred way to wire this?
Question 3 - If the answer to question 1 is no, what other options might there be? Would like to avoid cutting more holes for additional junction boxes if possible?
Hope this makes sense, any help would be appreciated.
ChuckEA is offline
Old 02-09-2007, 12:09 AM   #2
MO-AMPS's Avatar
Trade: Electrician
Re: Switched Receptacle- A Couple Of Questions
are you asking, if can you have two branch circuit in a common enclosure?
MO-AMPS is offline
Old 02-09-2007, 06:24 AM   #3
ChuckEA's Avatar
Trade: handyman
MO-AMPS - Yes, that is essentially the main question.
ChuckEA is offline
Old 02-09-2007, 08:24 AM   #4
whompus's Avatar
Trade: electrical general super
there are a few ways of handling this, the easiest way is to fish a wire into the 2 gang switch box(14-3), cut your hole for a popin box where you want your switch rec. fish the other end of the wire down to the box, put your red wire on one, break the tab on your hot side so half the rec switches, in your 2 gang box tie your hots together use your red a switch leg, go buy a stacked switched, and a 2 gang combo plate, then clearly mark what circuit this rec is on, and your on your way, if you don't like this idea let me know i'll give you another solution.
whompus is offline
Old 02-09-2007, 06:44 PM   #5
Union Electrician
Sparky Joe's Avatar
Trade: Inside Wireman
Just run a 14-2(for 15 amps) between the switch and the receptacle. Use this cable as a "switch loop" with 2 circuits in the switch box.
If you put 2 circuits on the same receptacle, then you'd have to do some rearranging in the panel so this receptacle could be on a 2 pole breaker. And a 2 pole AFCI is probably pretty spendy.
Oh and there's nothing wrong with 2 or more circuits in one box, Two circuits on one device gets a little complicated.
Sparky Joe is offline
Old 02-09-2007, 09:35 PM   #6
whompus's Avatar
actually, running a single 14-2 will only allow you to either turn the whole duplex rec on or off, by running a 14-3, you can, on the same circuit not 2 different curcuits, have a half hot half switched, black would be a constant hot, red would be a swith leg
whompus is offline
Old 02-09-2007, 10:07 PM   #7
MO-AMPS's Avatar
Trade: Electrician
I think you mean half hot duplex,not to saavvy on that code is that in compliance with NEC i really don't know but I'll check now. But what Sparky should be sufficient to your customer(talking to the OP).
MO-AMPS is offline
Old 02-09-2007, 10:57 PM   #8
Union Electrician
Sparky Joe's Avatar
Why would he need a 14-3?
Ever wired a 'switch loop'? where power is carried to the switch on the white and back from the switch on the black?
It's all part of the same circuit in the receptacle so the neutral is already there. Even if he used the circuit in the switch he would only need a 14-2.
Why is a third wire required? Shall I draw a picture?
Old 02-11-2007, 10:25 AM   #9
ChuckEA's Avatar
Trade: handyman
Thanks, that is exactly how I did it, used a 14-2 wire to carry the hot to and from the switch back to the receptacle.
ChuckEA is offline
Old 02-11-2007, 10:57 AM   #10
acrwc10's Avatar
Trade: Electrical contractor/General contractor/ ICC certified electrical inspector
THIS IS THE WAY A HANDY MAN SHOULD DO IT.
acrwc10 is offline
Old 02-11-2007, 11:02 AM   #11
Remodeler Extraordinare
A.W.Davis's Avatar
no way man....this instalation is much easier
A.W. Davis Construction Co.
http://www.awdavisconstruction.com/
Your friendly remodeling contractor
A.W.Davis is offline
Old 02-11-2007, 04:16 PM   #12
acrwc10's Avatar
How do you get "The Clapper"?
acrwc10 is offline
Old 02-11-2007, 06:00 PM   #13
Union Electrician
Sparky Joe's Avatar
Quit with all that clapping, you keep turning my lights on and off.
Old 02-11-2007, 08:36 PM   #14
MO-AMPS's Avatar
Trade: Electrician
Reason for that to keep half of the device(outlet) energize at all time
MO-AMPS is offline
Old 02-12-2007, 07:59 PM   #15
Union Electrician
Sparky Joe's Avatar
He's not adding a receptacle. Simply switching half of an existing receptacle......
Remember the question was to use the existing power at the receptacle or the existing power at the switch?
Old 02-12-2007, 08:07 PM   #16
A.W.Davis's Avatar
I love my clapper.....the only time I hate it is when I am slapping my wifes booty in bed and the bedroom lights turn on and off.
Old 02-12-2007, 08:25 PM   #17
whompus's Avatar
strobe lights
whompus is offline
Old 02-12-2007, 08:53 PM   #18
Union Electrician
Sparky Joe's Avatar
Yes the clapper does have it's limitations........
And 'booty' slapping is definetely one of them
Old 02-13-2007, 12:13 AM   #19
MO-AMPS's Avatar
Trade: Electrician
You right Bro.
MO-AMPS is offline
Old 02-15-2007, 09:20 AM   #20
whompus's Avatar
yup thats was the original question, then just break the tab and fish a 14-2 for a switch leg
whompus is offline
Couple questions from the new guy. n4rb Pressure Washing 3 01-27-2008 05:06 PM
Couple basic tiling questions fast pasquale Flooring 10 06-26-2007 02:40 AM
A couple of $ questions dkillianjr Business 25 12-13-2006 10:27 PM
Couple of trailer questions for the pros Mike Finley Vehicles 38 12-07-2006 12:36 PM
Couple Questions lukachuki Masonry 8 07-10-2006 09:34 PM
