Subpanel Inside New Garage?
Old 09-23-2005, 12:39 PM   #1
housedocs's Avatar
Trade: Home Improvement
I'm currently building a detached garage, we're needing to run 110 out there to power lights, door opener, and client will be using a fairly large compressor out there as well as an occassional saw, drill etc. They've requested 4 outlets & a couple of shop lights basically. Is it necessary for there to be a seperate panel inside the garage or can one simply run this off say a new 30 amp breaker from the house? I've tried getting an elec contractor out on the job, but it's a quite small job as you can see and it's way out in the sticks, so all I've asked have just flat declined or given me a date 6 weeks out when they can get to it. I kind of think there should be a sub panel in the bldg which sits about 35-40 feet behind the home. What say you elec pros?
"All you need in this life is ignorance and confidence, and then success is sure". -Mark Twain
housedocs is offline
Old 09-23-2005, 05:25 PM   #2
mdshunk's Avatar
Re: Subpanel Inside New Garage?
You're permitted to run up to 2 circuits to an outbuilding before you must install a panel. If I was you, I'd install a feeder rated for 60 amps, and feed it off a 60 amp breaker in the house. Set a small 8 or 12 circuit subpanel in the outbuilding with a main disconnect (main breaker) in it. You must have a main disconnect in the detached outbuilding.
mdshunk is offline
Old 09-23-2005, 05:31 PM   #3
Teetorbilt's Avatar
That is the exact same thing that my sparky told me to do.
If I remember correctly, you need to install a ground stake as well.
Albert Einstein
Teetorbilt is offline
Old 09-23-2005, 06:07 PM   #4
mdshunk's Avatar
Right you are.
I didn't really detail the whole installation, but if the original poster wants me to outline all the material necessary, I'd be pleased to prepare that list. My personal preference is also to ALWAYS install buried conductors in PVC conduit. Makes replacement down the road a snap. While you have the ditch dug, might as well install an extra small conduit for future phone or TV cable to the outbuilding too, is what I generally also advise.
Here's a really good link that pretty much gives you a step by step on installing power to residential detached outbuildings: http://www.selfhelpandmore.com/homew...rage/index.htm
mdshunk is offline
Old 09-23-2005, 07:40 PM   #5
Teetorbilt's Avatar
I ran water out there too.
Albert Einstein
Old 09-23-2005, 08:17 PM   #6
mdshunk's Avatar
Show off!
mdshunk is offline
Old 09-24-2005, 01:35 AM   #7
Teetorbilt's Avatar
BTW, water runs under elec. and over sewage.
Albert Einstein
Old 09-24-2005, 03:03 AM   #8
housedocs's Avatar
Thanks guys
Old 10-05-2005, 01:04 PM   #9
kenvest's Avatar
Trade: carpenter
how big a compressor does he plan on getting? if your working on anything serious, you'll need decent compressor which means 220 in my book.
kenvest is offline
Garage receptacle ChuckEA Electrical 21 04-27-2011 07:45 PM
High ceiling in garage construction T bone Construction 10 02-24-2007 10:57 PM
Laminate Wood Flooring Over An Old Garage Floor mjm0073 Flooring 1 01-30-2007 10:42 PM
Flat roof over garage leaking under exterior walk out door IHI Roofing 18 05-30-2006 10:28 PM
...continued...garage floor drain progress carlspackler Plumbing 0 05-27-2006 02:54 PM
