Trade: builder remodelor
Sub Panel Codes
question about sub panels and code reqs,is it ok to add a subpanel to exisiting service say 60 or 100 amp,and what maximum amps can sub panel be.Also does sub panel need to be located next to existing service panel or is say panel in garage and sub panel in basment ok.Also can 60 amp panel be replaced or must it be upgraded to 100 amp.
#2 | ||||
Re: Sub Panel CodesQuote:
Re: Sub Panel Codes
thank for info,i always try convince customer to upgrade to 200amp service if its only 60 or 100amp.But i see lots of previosly installed subpanels,usally are added as part of ac installation.
#4 | |
Re: Sub Panel Codes
My father in law has a 30amp 2 fuse service in summer house. Been trying to convince him to change it for years.I believe this is the original box from 1930's . btw what panel do you prefer,my electrician uses square d almost exclusivly.
#6 | |
Square 'D' has been around for a long time, and has much brand recognition. When a customer expresses a preference for Square 'D', I have no trouble installing that brand. If I'm doing a service upgrade and they already have smaller panels of that brand that are getting replaced, I install a new Square 'D' panel so that I can reuse all the old breakers to save them money. There are 5 variants of that brand. There was the "XO" breakers, which are totally obsolete, and are no longer made. There was the "Trilliant" type, which is still available at great expense, but was a marketing flop a decade or so ago. There's the "QO" type, which has been the residential standard for many decades. There is the "QOB", which is a bolt on version of the "QO", generally used in commercial applications. It would be expensive for a dwelling, but is a fine upgrade. Finally, in recent years there is the el-cheapo "Homeline" type, based on an old Westinghouse design. You see Homeline installed where price is the only concern. I mention this old Westinghouse design, because it is the design that most panel/breaker manufacturer's base their design on. Seimens, Square 'D' Homeline, Cutler-Hammer 'BR', Murray, ITE, Crouse-Hinds, T&B, Westinghouse, General Switch, most GE, etc. There's nothing wrong with this design, but it is low end. It also takes 1" tall breakers, which makes for a bigger panel. My preference, when the customer expresses none, is Cutler Hammer's 'CH' series. The breakers are 3/4" tall (like the QO's) and the buss bars in the panel are all copper (unlike QO). In addition, the CH breakers have an extra spring around the clips of the breaker where they clip on the bussbar that causes the breaker to clip on very tightly. Burnt bussbar fingers and burnt breakers (as a result of a loose clipped connectino) are common to find on QO panels. I have never observed such a failure on CH panels. The Cutler Hammer 'CH' panels are a little bit more in price than a QO, but better for many subtle reasons, in my opinion. There are many other features about the CH panels that make them easier for the electrician to work with. The short answer is, if the panel is UL listed, it's perfectly fine to use. It's sort of a Fords vs. Chevy's question. There's reasons on both sides. If money was no object, I'd install a bolt on breaker panel everywhere (like Square D QOB, or Cutler Hammer CHB), but that is just a dream. There was a brand in the past, called Federal Pacific, that has turned out to be a real hazard. Do a Google on that brand. Wow. If you see any Federal Pacific (FPE, sometimes) in any of your projects, I assure you that it's worth a service call to an electrician to have it looked over really well. Zinsco, Wadsworth, and PushMatic are a few other brands that have faded into the past. If you need to add much stuff to one of these obsolete panels, it is often cheaper to replace the panel than to buy more than one or two new old stock breakers for these obsolete panels. Last edited by mdshunk; 05-30-2005 at 12:57 PM. |
Re: Sub Panel Codes
His main reason for the square d panel is the number of breaker spaces,these are the smaller breakers. Heard about the federal pacific problems, never seen one though. could you explain what bolt on panel is.
#8 | |
Re: Sub Panel Codes
I think this is compared to less expensive panels sold at the big box.My own 200amp panel has only 32 spaces,byant murray type.
Re: Sub Panel Codes
Get a siemens panel,thats the best and cheapest,the breakers are good and interchangable with westinghouse,
Home depo has a good price on that. Dont forget to seperate the nutral and ground connection in a subpanel unless you run a seperate independant ground Last edited by hansdankers; 06-07-2005 at 12:49 AM. |
| Circuit panel height | JohnV | Electrical | 7 | 04-05-2008 11:21 PM |
| adding meter main panel?? | ko_jun | Electrical | 3 | 05-26-2007 10:42 PM |
| Sub panel | mjay | Electrical | 9 | 02-24-2006 11:41 PM |
| Upgrading Main Panel | DecksEtc | Electrical | 7 | 01-23-2006 07:54 PM |
