Trade: electrical
Sub Panel
Building a second flr additon going to be runnig a sub panel off the main which is a 100amp service.Going to be feeding the sub with a 60 amp my question is do i need to have a breaker in the sub panel as well.Thank you
#2 | |
Trade: Electrical contractor/General contractor/ ICC certified electrical inspector
Re: Sub PanelQuote:
If I understand your question correctly, you will have a 60amp breaker at the main that feeds the sub panel in the same building. No you would not need an additional 60amp in the sub panel. Now if it were going to a sepperate structure then it would. |
Trade: electrical
Re: Sub Panel
yes that was my question thank you for the response.Any suquestions on a panel looking to add about six breakers.
Re: Sub Panel
If your load calcs say it is ok. It all depends on what you put on it , but in residential unless you are putting heaters or heavy loads should be alright.
Trade: electrical
Re: Sub Panel
no heavy loads just some bathrooms and bedrooms.One more question i will be purchasing a ge panel should i install a 60amp single pole or a 60amp double in the main service to feed the sub panel and thank you again
Thom
Re: Sub Panel
Shok, that question about two pole or single pole doesn't make sense, especially from a guy who says his trade is electrical. We must assume your sub panel has both legs so obviously you would want to run both legs.
Trade: electrical
Re: Sub Panel
i am talking the 60 amp breaker at the main that will be supplying the sub panel there will be no breaker at the sub just the main.My question was a single pole 60 amp breaker or a double pole breaker at the main i am learning still and there is lots to learn out there thank you.
Celtic's #1 Fan
Trade: electrical
Re: Sub Panel
homeowner or apprentice...which one?
Trade: electrical
Re: Sub Panel
apprentice just starting out
Electrical Apprentice
Trade: Electrical
Re: Sub Panel
so is this your first week of being an appentice. I am also guessing you took no training before starting the trade because the question your asking is something a level 1 should know pretty quick.
If I was you I would use a DP in the main and run a 3 wire up to your subpanel. This will give you the option of haveing 240V loads at the subpanel. Unless you plan on putting in baseboards you probably can get away with using a single pole and only being able to have 120V loads at the subpanel. |
Re: Sub Panel
Then please ask one of your co-workers to give you a hand with your side job. You owe your customer a safe installation. I generally struggle to make the brand of the service panel and the load side panel "match", so that breakers can go back and fourth if need be, and the installation has one model of breaker associated with it.
Electrical Contractor
Trade: Electrical
Re: Sub Panel
A 60 amp single pole fed sub-panel is illogical. There is NO reason to do this.
You need a 3-wire (with ground) cable as suggested. 6/3NM would be a suitable cable to run to a 60 amp residential sub-panel. I also strongly agree that this is stuff you should already know before doing this work on your own!
Re: Sub Panel
Do they even make a single pole 60. That is such an odd question I can't ever recall seeing one. If they do I don't know why you would need it, and don't refer back to the OPers question.
Electrician
Trade: Electrician
Re: Sub Panel
Um, if you have to ask something that simple, you shouldn't be doing electrical work on your own.
listen twice talk once!
Trade: electrician
Re: Sub Panel
Make sure those bedrooms have smoke detectors.
Trade: Licensed Home Improvement Contractor
Re: Sub Panel
Uh OH this question falls in line with Air Pros Beef.
Union Electrician
Trade: Inside Wireman
Re: Sub Panel
Is there even such a thing as a single leg panel?
| Circuit panel height | JohnV | Electrical | 7 | 04-05-2008 11:21 PM |
| adding meter main panel?? | ko_jun | Electrical | 3 | 05-26-2007 10:42 PM |
| Sub panel | mjay | Electrical | 9 | 02-24-2006 11:41 PM |
| Upgrading Main Panel | DecksEtc | Electrical | 7 | 01-23-2006 07:54 PM |
