Stripping Uf Cable
Old 08-01-2007, 10:14 PM   #1
dkillianjr's Avatar
Stripping Uf Cable
Hey guys I was just curious. I was putting in a new post light at my house and as I was stripping the uf cable I was thinkin boy I wonder if there is a tool for this. Is there a tool for stripping it? What are some tricks you guys use to strip it with out knicking the wire?
Thaks, Dave
dkillianjr is offline
Old 08-01-2007, 10:16 PM   #2
mdshunk's Avatar
Re: Stripping Uf Cable
Yeah, Seatek makes a really nice one, and King makes a cheapie that would be good for a homeowner or DIY.
Sorry to learn that you ran UF cable. If you'd have called an electrician, he'd have run pipe and pulled conductors. You'll think of me in a few years when you're digging your ditch again.
mdshunk is offline
Old 08-01-2007, 11:19 PM   #3
Service & Repairs
Magnettica's Avatar
Trade: Electrician
Especially if he poured concrete all over the cable when setting the post.
I use a utility knife, slice a separation between white and ground, pull out the white, then the ground, and finally the ungrounded conductor.
You also want to stay away from using UF in the winter time.
Magnettica is offline
Old 08-02-2007, 10:30 AM   #4
Old Guy
househelper's Avatar
Trade: Electrician (semi-retired)
The specialty tools are OK, but I prefer a small utility knife. Score along the middle on each side, cutting hard in the last inch. Pull out the ground, which splits the cable, the black and white come out easily after that.
The real PITA are the /3 UF cables!
househelper is online now
Old 08-02-2007, 05:45 PM   #5
dkillianjr's Avatar
Thanks for the info guys. The cable dosen't go through the concrete but heck in a couple of years it might give me something to do over the weekend
Cat5e cable JasontheMason Low Voltage 16 03-14-2007 11:16 PM
Stripping paint on front porch birdog Painting & Finish Work 19 03-01-2007 07:15 PM
Cable Calc. sparkengineer21 Electrical 2 02-06-2007 07:01 PM
Coaxial cable and Electric amanandhisvan Low Voltage 2 12-28-2006 12:53 PM
Porter Cable Framing Nailers Reno Tools & Equipment 10 05-04-2006 11:44 AM
