"steal" A Neutral?
I have power from two different circuits in one box. (#1) I have a line (hot, neutral) from one circuit and (#2) hot only from another circuit (3way). I want to install another switch to control a fan in this box and want to run it off the (#2) circuit. Can I use the neutral from circuit (#1) to accomplish this? Logically, I can't see why not as the neutrals all lead back to the same place.
Thanks, artis |
Trade: builder remodelor
Re: "steal" A Neutral?
Are these circuits on same breaker??? If so i think this is a wire sizing issue.If not, probally a code violation to tie together.
It will work, but it will be a big red flag waving, jumping up and down code violation. NEC §300.3(B) states that all conductors of the same circuit must be contained in the same cable or raceway. You can't "steal" a neutral from a convenient place.
#4 | |
Electrical Contractor
Trade: Electrical
Re: "steal" A Neutral?Quote:
If we thought this way all the time there would be lots of charred homes and other nasty bits. This is one great big qualm I have with DIY electrical. The "Well, it works. Must be OK" mentality. This is not the way to go about doing electrical work. It is also why we have a big code book to refrence before doing any work. Short answer; as Marc said, it may physically work but it is a big violation and a very unsafe installation.
#5 | |
#6 | |
| 55 volts on both hot and neutral, what the heck!? | karma_carpentry | Electrical | 32 | 02-28-2009 09:12 AM |
| Need help with a shocking outside waterspout | Badoish | Electrical | 23 | 12-27-2008 04:18 PM |
| Reverse feed a broken neutral - K & T wiring | mdcorreia | Electrical | 3 | 04-06-2007 06:53 PM |
| Shared neutral with a GFI | darren | Electrical | 21 | 03-03-2007 06:38 PM |
| Ground & Neutral is Hot | Capt2 | Electrical | 27 | 01-15-2007 08:51 PM |
