Staples In Small Spaces - Page 2 - Electrical - Contractor Talk
Old 04-10-2015, 01:48 AM   #21
cedarboarder's Avatar
Trade: Workaholic
Rewards Points: 35
Re: Staples In Small Spaces
Originally Posted by jlsconstruction View Post
Don't run wire in tight spaces, problem solved.
you think they like running wire in tight spots? haha
my finger nail still grows funny from smashing it stapling in a small corner. Almost lost my nail but i used 1/16 drill bit to relieve the pressure .
cedarboarder is offline
The Following User Says Thank You to cedarboarder For This Useful Post:
m1911 (04-10-2015)
Old 04-10-2015, 09:49 AM   #22
El Conquistador
nunya01's Avatar
Trade: Master Electrician
Rewards Points: 166
I was going to drop some serious electrician magical wisdom today, but GettingBy beat me to the punch. A big set of channel locks does the trick. Just don't slip and mash the romex.
Apparently this isn't a new trick either - I've seen channel lock grooves on studs in demo'd walls from 65 years ago.
If it's a doubled up stud, then the tie-wraps with screw holes work well.
nunya01 is offline
Old 04-10-2015, 11:30 AM   #23
Chillin' the Most.
walkinplate's Avatar
Rewards Points: 420
My electrician uses cable stackers with the nail offset at an angle so he can nail it from the front.
walkinplate is offline
Old 04-10-2015, 01:05 PM   #24
madmax718's Avatar
Trade: General
Rewards Points: 3,252
outdoor? trellis? With stapled romex? (interesting). Your the sparky!
Anyways, for staples in tight areas, I use a super long needle nose pliers try to press in place, and then use the (yep) channel lock to beat it into position. But I beat on the pliers, not the staple itself, to prevent deformity.
madmax718 is offline
Old 04-10-2015, 08:22 PM   #25
cwatbay's Avatar
Trade: Electrical Contractor
Rewards Points: 2,106
This was few months ago. The romex was direct burial romex. We ran conduit as far as we could. Two 2 x 6's with a 2 x 4 between them. That means a 3 1/2 in +/- space between the two edges. The romex had to be up in the "trough" as high as possible. No marks on the white painted wood and no "misses" with a hammer.
The MC or similar strap would have worked. As it was, I used UV resistant zip ties with eyelets to get it up there and out of sight (for the most part).
cwatbay is offline
The Following User Says Thank You to cwatbay For This Useful Post:
madmax718 (04-14-2015)
Old 04-13-2015, 11:32 AM   #26
saynever's Avatar
Trade: electrical
Rewards Points: 229
My father in law was cleaning out his basemen a while ago. Gave me one of those h.o. Craftsman battery nailers. I actually used it yesterday in a tight spot. Worked good.
The channel locks is a trick I will use in the future.
saynever is offline
Old 04-13-2015, 05:16 PM   #27
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 13,864
Banging in staples with pliers is the only way I've ever put em in.
Inner10 is offline
Moling in a new water main at a small office building Cuda Plumbing 0 10-15-2012 06:50 PM
cedar fence and small historic deck swartzj81 Decks & Fencing 2 09-02-2012 03:01 PM
business plan for a small cabinet shop NEED INPUT finakat General Discussion 4 08-31-2012 07:40 PM
Retro fit lighting in office spaces, mostly troffer 2*4 lights joshR General Discussion 1 07-29-2012 07:29 AM
Billing on small jobs Philly Dude Business 14 11-16-2008 04:25 PM
