Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Electrical
Old 10-27-2009, 12:26 PM   #1
Sprinkler Line
Not sure if this should go here:
Doing some digging and I cut the control line for a sprinkler system (a small yellow wire of 4 parts).
I can repair the PVC fine, but have no idea whether I should tackle the electric line or not.
Main questions:
1) If I mess up the repair are there any fire hazards? The line is completely underground and nothing near the control box has been disturbed. So if water would get into the connection or the connection was faulty I think it would just trip the breaker? THoughts?
2) If this is doable, how do I ensure a water tight connection?
HammeremmaH is offline   Reply With Quote
Old 10-27-2009, 12:35 PM   #2
Trade: Electrical Helper
Main questions:
No fire hazard, its 24 volts. Twist the wires good and use some good grease filled wire nuts, not the cheapo ones.. You could just bury it, but if you want to be a sweetheart you can set a small, like 6" round, irrigation control box over it in case something goes wrong some time.
crazyboy is offline   Reply With Quote
Old 10-27-2009, 12:37 PM   #3
Crash Test Dummy
ChainsawCharlie's Avatar
Trade: Landscaping
No fire hazards. And it should be low voltage line.
Splice and tape with waterproof tape or waterproof splices. Electrical or irrigation supply should carry both.
ChainsawCharlie is offline   Reply With Quote
Failed inspection--CSST flexible gas line ChrWright Plumbing 7 07-28-2009 01:43 PM
Bricking above the roof line dakzaag Masonry 23 01-25-2009 03:28 PM
condensate draining into waste line flashheatingand Plumbing 7 07-18-2008 06:36 PM
Line levels Tscarborough Masonry 26 03-15-2008 11:58 AM
Shingles Nailed Above Nail Line.. Help!! Unregistered Roofing 20 04-25-2004 10:38 AM
