Speaker Wire
Old 02-12-2009, 07:31 AM   #1
Home Work Pro's Avatar
Speaker Wire
I am in the middle of a basement remodel and I need to run speaker wires above a suspended ceiling. There will be a 100 watt home theater system with a max distance run of 30 ft. What gauge wire would be recommended for these runs? Thanks Brian
Home Work Pro is offline
Old 02-12-2009, 08:45 AM   #2
GregS's Avatar
Trade: Low Voltage
Re: Speaker Wire
14g would be fine.. Do NOT use the transparent crap.
Are you not using someone to do the home theatre design/install for you?
GregS is online now
Old 02-12-2009, 09:32 AM   #3
MSSI's Avatar
Trade: Electrician
Re: Speaker Wire
By code you need to use CL 2 or better.
MSSI is offline
Old 02-12-2009, 04:54 PM   #4
Re: Speaker Wire
The homeowner is putting the system together himself. I just offered to run the wiring before I install the ceiling.
I'll be happy to sell you his phone number if you want to come to north east Ohio and warm up.
What is cl2 and where do I buy it locally, or is 14g ok above a suspended ceiling?
Old 02-12-2009, 08:16 PM   #5
CanadianLowVolt's Avatar
Trade: Low Voltage Audio/Video/Networking
Re: Speaker Wire
It's a Class rating for the cable by the National Electrical Code, signifying its suitability for in-wall installation. It's jacketed 99% of the time in an opaque jacket (usually white) with the conductors insulated individually inside the outer insulation.
EDIT: Since CL2 is a rating, you want 14 gauge cable that's CL2 rated. If you see designations like 14/2 and 14/4, the /# signifies the number of conductors. You probably want 14/2.
CanadianLowVolt is offline
Can I split thermostat wire??? Jambruins HVAC 5 01-13-2009 06:29 PM
Outdoor 18 ga wire vs. 18 ga Lamp Cord? Greg Di Electrical 8 10-21-2008 11:42 PM
3-way switch with 14/2 wire wadswob Electrical 2 09-23-2008 08:33 AM
