tags, as close as possible to the opening tag. Creation Date: 12/20/2017 -->
Spacing Recessed Lights In Great Room
Old 03-07-2018, 07:08 AM   #1
RookiePlumber's Avatar
Trade: HVAC install and repair
Rewards Points: 260
I am installing 4” dimmable LED recessed lights in a great room. The room is 23' 1/2" x 22' 1/4”. (281” x 265”). There is a kitchen in one corner and the rest of the space is free floating for dining and living space.
My question is how do you space the lighting in the room. I’d like to start by placing lights in the kitchen and then work my spacing out to the rest of the room.
My kitchen cabinets are 24” deep. Should I place my first light off the kitchen wall at 30”? That should provide ample lighting for the countertop space. And then center the next light on the kitchen peninsula? That works out to 5’" feet from the first light. The peninsula is drawn incorrectly in the diagram - it should be 38” wide. I extended it in pencil. The rest of the lights (3 more for a total of 5) in that column run at 4’ 6" spacing so that the 5th light ends up 30” from the opposing wall. Will the transition from 5' spacing to 4'6" foot spacing be obvious?
I will apply the same logic on the row of lights. Start at 33” off the wall, then space the next 3 lights (total of 4) 5’6” apart. That will leave the forth light 34 1/2” off the opposing wall.
All of the lights will be lithonia bright white 3000K 4” LED on a lutron dimmer EXCEPT the lights by the fireplace and brick wall which will be 4” recessed gimbals.
Is this a sound lighting plan? Are there too many lights in the room?
THANKS!!
RookiePlumber is online now
Old 03-07-2018, 07:27 AM   #2
jeffmattero76's Avatar
Trade: Property Manager
Rewards Points: 26
Re: Spacing Recessed Lights In Great Room
http://recessedlighting.com/recessed...ng-calculator/
I used the above calculator and it worked great.
Sent from my SM-G530T using Tapatalk
jeffmattero76 is online now
The Following User Says Thank You to jeffmattero76 For This Useful Post:
RookiePlumber (03-07-2018)
Old 03-07-2018, 08:10 AM   #3
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 10,500
4-inch, 5-inch, 6-inch, 7-inch..... totally meaningless.
What matters is the photometrics of the lamp itself. How much light does it produce, and how does it distribute it?
The other most important factor in the equation is height. 8'? 9'? And is the ceiling flat or vaulted?
Why is there not a Flat Mars Society?.
480sparky is online now
The Following User Says Thank You to 480sparky For This Useful Post:
Old 03-07-2018, 08:42 AM   #4
Rewards Points: 260
Ceiling is 10’1”.
Light output is 675 lumens.
Old 03-07-2018, 09:04 AM   #5
Rewards Points: 26
Originally Posted by RookiePlumber View Post
Ceiling is 10’1”.
You might also want to know the beam spread angle, but I am not sure if that is listed on those trims or bulbs.
Old 03-07-2018, 09:10 AM   #6
480sparky's Avatar
Photometrics............... like this.
Old 03-07-2018, 11:30 AM   #7
tang's Avatar
Trade: Remodel contractor
Rewards Points: 245
Looks like a lot of cans, but only four in the kitchen. I would add under cab lights for task lighting, and maybe pendents over the island.
tang is offline
The Following User Says Thank You to tang For This Useful Post:
Old 03-07-2018, 04:18 PM   #8
Rewards Points: 260
Jeff with 10 foot ceilings the beam spread is 24 ft.
Old 03-07-2018, 04:31 PM   #9
480sparky's Avatar
Here's what I would do:
The Following 2 Users Say Thank You to 480sparky For This Useful Post:
B.Johnson (03-07-2018), RookiePlumber (03-07-2018)
Old 03-07-2018, 05:45 PM   #10
Box Builder
Morning Wood's Avatar
Rewards Points: 8,946
Are there upper cabinets or n the kitchen? Is the peninsula totally open or does it have uppers? 10’ ceiling it’s probably open.
Morning Wood is online now
Old 03-07-2018, 05:51 PM   #11
480sparky's Avatar
No uppers shown in the plans.
Old 03-07-2018, 06:10 PM   #12
Rewards Points: 260
There are upper cabinets on the back wall where the sink is. No cabinets over the peninsula. There will be a range hood with a light over the cooking surface.
Old 03-07-2018, 06:26 PM   #13
Rewards Points: 260
Thanks - I was under the impression lights in a large room had to be symmetrical. This opens up options
Old 03-07-2018, 06:32 PM   #14
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 2,049
What Ken drew is symmetrical. But it's your place, you can do whatever you want.
Tinstaafl is online now
Old 03-07-2018, 06:45 PM   #15
480sparky's Avatar
Well, not totally. The kitchen lights don't line up with anything else, neither do the two over the fireplace.
Old 03-07-2018, 07:09 PM   #16
Capra aegagrus
Tinstaafl's Avatar
Don't argue with me, whippersnapper. Those are zones with their own symmetry.
Morning Wood (03-07-2018)
Old 03-08-2018, 05:04 AM   #17
Rewards Points: 260
why is the spacing between 2 & 3 greater than the spacing between 1 & 2. See pic
Old 03-08-2018, 07:19 AM   #18
480sparky's Avatar
Because I didn't use a $5000 CAD program.
Fouthgeneration (03-10-2018), RookiePlumber (03-08-2018)
Old 03-12-2018, 04:29 PM   #19
Rewards Points: 260
Went with your zoned layout and it came out great. Thanks 480!
Old 03-12-2018, 04:37 PM   #20
480sparky's Avatar
That'll be $1200 for consultation and layout fees. I accept checks, cash and PayPal.
Recessed lights and thicker ceilings Morning Wood Electrical 8 01-16-2013 07:02 PM
Can you install recessed ext. soffit lights in pre-vented soffit board? kansasflooring Carpentry 2 03-30-2011 04:04 PM
Great Room/ High Ceiling Wall Trim Tkelly Finish Carpentry 9 01-13-2011 10:18 PM
Recessed light spacing andeeznuts Electrical 12 09-28-2010 07:27 PM
Recessed lights and NatGas renoguy Electrical 7 04-01-2009 04:50 AM
