Something I Found In Our Home's Kitchen
Old 04-16-2007, 10:39 PM   #1
Remodeler
MinConst's Avatar
When adding some stone back splash to our kitchen and turning off the breakers for the outlets I found this to be strange.
I have 3 GFCI duplex outlets on the counter along with other protected duplex outlets. 2 of the GFCIs are on the same circuit. Is this not wrong? Did the sparky just stick it in to make it look good or what?
I have been under the assumption that one GFCI per circuit is proper.
Paul
Minichillo's Construction
Website
I will never leave you hanging!
MinConst is offline
Old 04-16-2007, 10:43 PM   #2
mdshunk's Avatar
Re: Something I Found In Our Home's Kitchen
Eh, he might have done that to keep the frige off the GFCI, if the circuit started at counter space on one side of the frige, and continued at counter space at the other side of the frige. Just a guess. Don't get too worked up about it.
mdshunk is offline
Old 04-16-2007, 10:51 PM   #3
Remodeler
MinConst's Avatar
Thats not the case and I am not worried about it just found it odd.
The room goes like this fridge on right end of L shaped counter. Then a GFCI for the stove and one other outlet. Sink, then the two GFCIs on the left end of the L.
Thanks for the quick reply.
Paul
Website
MinConst is offline
Old 04-16-2007, 11:14 PM   #4
mdshunk's Avatar
Couldn't just been a goof, too. I'm sure I've occasionally put in the extra GFCI by accident. I try to leave my ruff in such a way that I can tell (visually) which boxes need GFCI's just by looking quickly at the box makeup. Sometimes, tile guys and drywallers will mix things around in the box. That screws me up every once in a while. No biggie.
mdshunk is offline
Old 05-03-2007, 01:06 PM   #5
daveselectric
daveselectric's Avatar
Trade: Electrical
Hey MD,
Which conductors do you identify for gfi, line or load? Just curious. I strip off a piece of romex sheath about 2 inches and write "line" with a felt pen and slip that over my wires. Works for me and I leave the sheath on when I trim for the future amateurs that may have to change out the device.
daveselectric is offline
Old 05-03-2007, 04:56 PM   #6
Baltimore Electrician
JohnJ0906's Avatar
Trade: Electrician
I'm not MD, but I'll reply anyway Usually around here most electricians strip 1/2" of insulation from the line hot and line neutral.
John from Baltimore
"One Day at a Time"
All replies based on the 2008 NEC
Originally Posted by celtic
Deny Everything, Admit Nothing, Demand Proof
JohnJ0906 is offline
Old 05-03-2007, 05:06 PM   #7
mdshunk's Avatar
I either tag both conductors with a pice of romex jacket, or skin out a little bit of the hot and neutral of the line side. Whatever way suits me on any given day. If I only have two cables, I don't mark them. The left most cable is always my line side.
mdshunk is offline
Old 05-04-2007, 09:33 PM   #8
MSSI's Avatar
Trade: Electrician
Originally Posted by daveselectric View Post
Hey MD,
atta-boy
MSSI is offline
Old 05-05-2007, 04:14 AM   #9
macmikeman's Avatar
Trade: Master Electrican, Electrical Contractor
Neither the NEC or the manufacturer's of the devices prohibit the installation of a gfi receptacle outlet downstream fed off of another gfi device. There is nothing wrong with it. It might cause a bit of inconvienience to whoever has to go searching for the right button to reset however. You know when you are at a construction site and you plug in your gfi pigtail box into a gfi outlet provided for the workers you are doing the exact same thing.
macmikeman is offline
Custom Homes - Building Superintendent Needed: Charlotte, NC CWPritchard Help Wanted or Looking For Work 2 04-02-2011 09:04 AM
Bath & Kitchen Remodeler wanted for Upstate SC SCDreamMaker Help Wanted or Looking For Work 0 05-23-2007 10:50 AM
Performance System Built Homes and Energy Efficiency Hello john haddad Introductions 0 11-11-2006 11:09 AM
Drug caches found in Home Depot vanities HandyAl General Discussion 1 06-14-2006 08:14 PM
Custom Homes - Building Superintendent Needed: Durham, NC CWPritchard Help Wanted or Looking For Work 0 04-11-2006 11:40 AM
