zapped
Trade: plumber
Soldered Joints
i am a plumber, we like to solider everything
is it legal, to solder with solder iron , connections in residential wireing i am talking about the pigtail connections in the switch boxs and receptical boxs, copper to copper |
Re: Soldered Joints
Yes, it's still legal, and some people still do it. It's just a wasteful practice with no defined benefit.
| The Following User Says Thank You to mdshunk For This Useful Post: | bwalley (02-16-2009) |
Electrical Contractor
Trade: Electrical
Re: Soldered Joints
It certainly is "legal". You just can't rely on the solder alone for the connection.
zapped
Trade: plumber
Re: Soldered Joints
i hear ya ...i ran into a bunch of loose grounds..causing light bulbs to pop to soon...i tighten wire nuts and the bulbs last longer
so....frig that..gonna solder the ends.. is there a code on this? is it in like connections ,approved ? |
Pompass Ass
Re: Soldered Joints |
Fentoozler
Re: Soldered Joints
Didn't we just do this dance?
zapped
Trade: plumber
Re: Soldered Joints
yes we did...but sence i am not a electrican,,,that site refused me to post
i am a plumber not a electrictian..and that was elec.talk.,com so..i came over here ..i am argueing with a bud on the legality of this he says no i say yes... |
Trade: Plumbing & HVAC, I specialize in Hydronic Heating and more specifically in Radiant Floor Heating
Re: Soldered Joints
But loose neutrals can right?
Thinking back to a job where the light bulbs were dim. As soon as you started the saw they got really bright and popped. Poor neutral connection. |
zapped
Trade: plumber
Re: Soldered Joints
thank you for calling me a knuckle head...i said i was a turd herder not a sparky..the lights kept poping, then when i tighten the ground it seemed to stop..so i figured..
zapped
Trade: plumber
Re: Soldered Joints
it could very well be the neutrals, i tightened them also
it seems to be in more than one location.. |
Service & Repairs
Trade: Electrician
Re: Soldered Joints
Can we use duct tape for leaky sink pipes?
zapped
Trade: plumber
Re: Soldered Joints
yes..2 plumbers debating a electrical problem at my house
the loose wires...popping bulbs..have been pissen me off so i am going to either go thru the house tightening nuts or soldering pigtails.. and tightening ground bar, nuts in panel. |
zapped
Trade: plumber
Re: Soldered Joints
no...dont use duct tape...buy that spray stuff they sell on tvaround 2 am
be sure to read directions as you spray |
And I do electrical, too!
Re: Soldered Joints
Doesn't reading the instructions as you spray make it difficult to both read the instructions and spray?
Site : the area or exact plot of ground on which anything is, has been, or is to be located. Sight : The power or faculty of seeing; perception of objects by use of the eyes; vision. Cite : To mention in support, proof, or confirmation; refer to as an example. |
Trade: Union Carpenter
#18 |
woodchuck2
Re: Soldered Joints
X2, IMO there is a time and place for soldering electrical connections and i wouldnt bother for this industry. But when i worked in the automobile repair field a soldered joint/heat shrink was the way to go to prevent water intrusion and breakage from vibration. Butt splices are noted for crimping on the wire and over time the road vibration will cause it to fail over time.
#19 |
#1 stunner
#20 | |
Fentoozler
Re: Soldered JointsQuote:
| Joints in Top Plates | orson | Framing | 55 | 08-08-2010 09:19 PM |
| Azek butt joints holding up? | LeonardDB | Finish Carpentry | 39 | 11-28-2009 08:30 PM |
| Gutter joints leaking | JTW | Roofing | 4 | 02-13-2009 07:45 PM |
| Control/Movement joints | Cache | Flooring | 6 | 11-02-2008 01:10 AM |
| Hardwood Floor Pattern and End Joints | 4yanx | Flooring | 25 | 07-29-2007 07:14 AM |
