Solar Power
Does anyone have experience with solar power panels? What is the best company from which to buy the panels and inverters? Seimens seems to have quality with high current values. Other than location, what are the major parameters in deciding to go at least part solar?
Sprinkler Guy since birth
Trade: Lawn Sprinkler/Fence Contractor
Re: Solar Power
How much power do you need your solar to supply every day?
How long each day does your site receive adequate sun? Planning to do a grid tie in or stand alone? I am no expert, but I have installed and serviced a bit of solar this past year w/ a contractor and picked up some things. I know that it is important to calculate how much energy this home will use each day.....in order to calculate how much energy you need to produce....if you can produce it and store it efficiently (cost-wise) then go for it. If it turns out that the solar system you need will be too large to be cost efficient..don't bother. Go to Realgoods dot com...they have a ton of info on their site...good luck, ask specific questions, I won't answer them if I don't think I can help.
Tony Neumann Lawn Sprinkler Repair and Irrigation Installation Colorado Springs, Colorado http://www.sprinklersolutions.com |
| Run a Heat Pump on solar power | SR Martin | HVAC | 173 | 11-20-2010 12:38 PM |
| Solar Power Industry Dead In California | w6ire | Electrical | 2 | 06-28-2007 09:57 AM |
| Power Outage Question? | Ron The Plumber | HVAC | 5 | 12-20-2006 09:42 AM |
| Water heater, elec., power surge problem ??? | tzzzz216 | Plumbing | 8 | 11-05-2006 10:24 PM |
| Trailer shore power | RobertCDF | Vehicles | 12 | 10-10-2006 06:56 PM |
