Smoke Detector Chirping
Old 03-22-2009, 09:20 PM   #1
topsail's trimcat
woodworkbykirk's Avatar
hey guys,
i had my place upgraded to 200 amp service last year, at the same time the smoke detector was switched over to a hardwired unit. the issue is that the detector lets out a quick chirp once every 30 seconds. ive disconnected the thing and reconnected, tried resetting it, changed the backup battery in it and it still does it. what else could it be?
its driving me nuts!! any help would be awesome, btw im redoing alot of the old woodwork and ive encountered some detectors which go off when there is alot of dust in the air, coiuld it have something to do with this? mind you im doing most of my cutting outside
woodworkbykirk is offline
Old 03-22-2009, 09:22 PM   #2
Service & Repairs
Magnettica's Avatar
Trade: Electrician
Re: Smoke Detector Chirping
Have u tried taking a hammer to it yet?
Magnettica is offline
Old 03-22-2009, 09:24 PM   #3
Professional Instigator
rbsremodeling's Avatar
Originally Posted by woodworkbykirk View Post
hey guys,
I have seen issues if the brands where slightly different models they did not play nice with each other.
The electrician swapped out the chirping one to a identical match and presto
rbsremodeling is offline
Old 03-22-2009, 09:30 PM   #4
Custom Stuff
Mike(VA)'s Avatar
Trade: General Contractor - Custom Renovations
Better yet, swap out the older units with new ones compatible with the chirper.
__________________________________________________ ___________
I EXPECT THAT SOMEDAY I WILL SEE THE FRUITS OF MY LABOR. IS IT SOMEDAY YET?
Clifton, Great Falls, McLean, Fairfax Station, Manassas, Virginia Renovation Contractor
Mike(VA) is offline
Old 03-22-2009, 09:31 PM   #5
And I do electrical, too!
480sparky's Avatar
If you have just one hard-wired smoke, then it's a defective unit. Buy another one tomorrow and sleep well.
If there's more than one, and they're interconnected, you may need to replace it with one that is compatible with the rest.
Dust in the unit will not cause it to chirp. It should, if anything, cause it to go into alarm as it sees the dust as smoke.
Site : the area or exact plot of ground on which anything is, has been, or is to be located.
Sight : The power or faculty of seeing; perception of objects by use of the eyes; vision.
Cite : To mention in support, proof, or confirmation; refer to as an example.
480sparky is online now
Old 03-22-2009, 09:37 PM   #6
topsail's trimcat
cool, ill ask get in touch with my sparky somepoint tommorrow to see if he'll cover this
Old 03-22-2009, 11:58 PM   #7
Capra aegagrus
Tinstaafl's Avatar
Also, make sure that the backup battery is exactly the type specified by the manufacturer. Shouldn't make a difference, but once in a blue moon it does.
Tinstaafl is online now
Old 03-24-2009, 08:51 AM   #8
woodchuck2
woodchuck2's Avatar
I agree with everyone here, these are fussy little buggers. I dropped one in my own home once on the carpet and about a week later then damn thing would intermittenly go off. And of course it would set all 18 of them off . It took me several weeks to find out which one was the problem, we didnt get alot of sleep until i found it.
woodchuck2 is offline
Chirping Smoke Alarm Kidde Bubbles Electrical 14 05-05-2009 07:37 PM
Smoke Odor VBuilt Remodeling 12 05-02-2009 09:43 PM
Can't put the smoke back in. Careless? maybe.. poor design? definitely! Electric_Light Low Voltage 2 01-11-2009 04:01 AM
Fire and Smoke Damage? kdub1777 General Discussion 2 07-02-2008 09:33 PM
Source for Smoke bombs??? a1plumbingyakim Plumbing 3 01-11-2007 12:51 AM
