Smart Light Switch Circuit
Old 12-06-2005, 07:46 PM   #1
toastermaker's Avatar
Trade: electrical
I will be working on a three way switched light circuit. It is apparently an upscale installation. This is the first time I have seen this.
The switch at one location is either tied in to a controller or is itself some kind of smart switch.
It has both motion detection, timing and a rocker style wall switch at that location.(top of the stairs that go from ground level to the first floor)
The other location (bottom of the stairs) is missing the switch, but I believe it to have been a more (though not completely) standard rocker style switch. My best guess is that it was a momentary-on switch. <I will tell why I think that if it would help someone help me.>
My problem is I will have to replace the missing switch. I am hoping someone can point me in the right direction?
Do these type of installations have usual and customary hardware as far as the "dumb" switch goes?
I know how to wire a standard three way switch circuit. Please don't feel you need to explain a basic three way switch circuit to me.
Thanks for any help and replies,
toastermaker is offline
Old 12-06-2005, 09:44 PM   #2
Electrical Contractor
jbfan's Avatar
Trade: Electrical Contractor
Re: Smart Light Switch Circuit
I have installed those before. You will need a pair for them to work. It will not take a "dumb" switch.
We are the people (our parents warned us about) (Jimmy Buffett)
jbfan is offline
Old 12-06-2005, 11:01 PM   #3
toddgotfish's Avatar
Trade: Electrician
you will need a master , and a slave. it will not wire as a standard three way either.hope this helps
toddgotfish is offline
Old 12-06-2005, 11:06 PM   #4
mdshunk's Avatar
You almost always need manufacturer specific data for these "system" type multi location switches. Every brand and model is screwy in its own special way. I did install some Zenith brand occupancy sensing switches once that would inter-tie with standard 3ways and 4ways if need be. You might have to get the brand and model off the existing switch and pull up some data on the net or call their tech support line.
mdshunk is offline
Old 12-07-2005, 06:47 AM   #5
Trade: electrical
Thanks everyone,
I will stop by the job site as soon as I can and look for
manufactures information on the available switch.
At least I now have some basic understanding and
commom terminology thanks to all of you. That will
help me alot as I proceed.
Thanks again,
Old 12-07-2005, 09:21 AM   #6
K2's Avatar
I have an occupancy sensor here to a standard 3-way but my experience is that the sensors don't last forever which may be the reason someone pulled out your bottom switch. It might end up less expensive to replace both parts. I do like sensors for a number of reasons even it they can be fickle.
K2 is offline
Old 12-07-2005, 10:41 PM   #7
Chief Toilet Mover
Mike Finley's Avatar
Trade: Bathroom Remodeling
I tried one of those. I thought it would be great in our hallway coming in from the garage so when you come in with groceries in your hands you don't have to fumble for the switch. I went through 2 different brands, never got them to work right. The best I got out of it was one worked for about a 3 days. I love the idea, I just can't get it to work for some reason.
Mike Finley is offline
Old 12-07-2005, 11:45 PM   #8
K2's Avatar
I think most of them need a neutral which may not be available in all situations. Of course that would not make it fail after 3 days. My part time job had a contract with the school district for 120 schools over a 5 year period with some occupancy sensors. After about 1 year the change order came in to eliminate the os's we put in and to delete them from the rest of the contract. Several brands were tried. Lamp life was one issue but there were failures also.
K2 is offline
light switch plate blank darren Electrical 12 06-14-2007 08:06 PM
Light switch lock darren Electrical 10 05-08-2007 08:08 PM
Light Switch at Landing? thom Electrical 22 04-01-2007 11:10 PM
Inground pool light circuit louis bugaj Electrical 28 11-07-2006 11:19 PM
