Slot Machine Sound Agitating
Old 12-08-2008, 09:01 PM   #1
Master Electrician
Bubbles's Avatar
Trade: Electrical
I'm probably breaking the rules here..but I just had a strange request. The job of the ground/neutral..well..her boss asked if I could disable the sound of the slot machine while I was there. I think it's a bally's from the 90's. He said he's an electrician right...don't they fix things like that. Is this over my head or can I just open it up and find the low voltage line to speaker and snip. I'll look like a genius if I can pull this off. Any tips welcome or should I not get involved?
thanks
Bubbles is offline
Old 12-08-2008, 09:04 PM   #2
mickeyco's Avatar
Trade: Squirrel Handler
Re: Slot Machine Sound Agitating
I would suspect so (it's what I do to the seat belt alarm on my vehicles), but why not put a toggle switch out the back so they can have the sound on or off.
mickeyco is offline
Old 12-09-2008, 07:43 AM   #3
MSSI's Avatar
Trade: Electrician
You are able to program them to run wthout sound. Some will have dip switches, some will have a jumper setup and some will have a program sequence by pressing a combination of buttons. If the manual is inside that will tell you. If you cant find the book do the ol toggle switch method mentioned above.
MSSI is offline
Old 12-10-2008, 10:15 AM   #4
Electrician
jrclen's Avatar
Trade: Electrical Contractor
Be a hero. Snip the speaker wire. If they want sound again, splice it back together.
I want to do that on my grandson's stereo.
John
jrclen is offline
Old 12-10-2008, 06:38 PM   #5
MSSI's Avatar
Trade: Electrician
Now that ive given it some thought...Some have a volume control as well.
MSSI is offline
Sound proofing underlayment under vinyl floor, Where & What, Pricing? MazalBuild Flooring 20 11-21-2008 08:15 PM
Hot Water Heater making loud sound and vibrating the entire wall BKFranks Plumbing 9 10-27-2008 10:58 PM
sound control dnconstruction Construction 9 09-24-2008 07:13 PM
A B C slot cutting for recompaction. MC Excavating Excavation & Site Work 17 03-13-2007 07:04 AM
Strange and bad English translation CE1 Off Topic (Non Trade) 4 09-01-2006 09:33 PM
