Sink Garbage Disposal Will Not Shut Off
Old 06-07-2006, 11:13 AM   #1
smcgowan@msn.co's Avatar
Trade: Heating/cooling
Very perplexing problem with kitchen sink disposal. To begin with the disposal was clogged and as a result would go on motor overload. I freed up clog by turning motor with allen wrench provided by manufacture. Then motor and disposal worked fine. However wall switch would not shut off disposal. So naturally I thought wall switch was bad so I replaced it. Guess what--it still didn,t shut off disposal. For some reason the the plug-- in under the sink is still live . House only fives years old and disposal has been working fine. Any help would be appreciated.
Thanks Terrmac:
smcgowan@msn.co is offline
Old 06-07-2006, 03:08 PM   #2
General Contractor
jensenconstruction's Avatar
Trade: General Contracting and Painting
Re: Sink Garbage Disposal Will Not Shut Off
Try the other receptical on the outlet, only one might me connected to the switch with the other hot all the time
jensenconstruction is offline
Old 06-07-2006, 08:24 PM   #3
mdshunk's Avatar
Yep, I concurr. I wire them this way most of the time (if I remember). One half on the switch for the disposer, and the other half hot all the time for an instant hot water dispenser.
mdshunk is offline
Old 06-08-2006, 12:32 AM   #4
Union Electrician
Sparky Joe's Avatar
Trade: Inside Wireman
or dishwasher
Sparky Joe is offline
Old 06-08-2006, 01:16 AM   #5
It turned out just like you all suggested. Half of the receptacle was hot all the time and the other half was controlled by the switch. I just changed the disposal cord to the other half and it works like a charm. Thanks to all of you
Need help! Hole for sink cut too big! sage Plumbing 32 02-05-2009 03:10 PM
Garbage Disposal Backup handymansol Plumbing 11 02-02-2007 06:51 PM
Disposal in double sink dzd9fy Plumbing 10 01-28-2007 12:06 AM
Garbage Disposal Mike Finley General Discussion 12 12-28-2005 12:18 PM
Bathroom sink question Robie Plumbing 6 12-07-2005 10:23 PM
