Trade: Project Manager
Simplex 120-volt Fire Panel
I'm looking for a 120-volt Simplex Time Recorder Company (now known as Simplex Grinnell) fire panel. Model # 4247-2. The current panel has recently lost supervision so it is in constant alarm mode and the reset doesn't work. The panel consists of some small circuitry but it is mostly just relays. All the bells and the panel are 120v which shows just how old it is, but it would be tens of thousands of dollars cheaper for me if I can find an exact replacement panel anywhere or somebody in Southern California who would be able to fix the existing one. Does anybody know any distributors who have old 120v fire panels or who is good at repairing them?
Thanks, Ethan |
#2 | |
Baltimore Electrician
Trade: Electrician
Re: Simplex 120-volt Fire Panel
Did you try Simplex Grinnell? Even if they don't make replacements, they very well might know someone who services and repairs these.
John from Baltimore "One Day at a Time" All replies based on the 2008 NEC Quote:
Union Electrician
Trade: Inside Wireman
What does the Fire Marshal think of this panel always being in alarm mode? I doubt he cares if the customers need to spend some money to upgrade/fix their equipment.
I doubt the employess of this business care what it costs either Last edited by Sparky Joe; 04-13-2007 at 09:45 PM. |
I never miss an opportunity to say, "yeah, they don't make a replacement for that anymore. Here's your bid for a new one". The 'hero' mentality will put (or keep) you in the poor house.
Trade: Electronic Systems Contractor
That panel was probably installed pre 1970! This is a new millenium man! No really, you would be lucky to find a part to repair that panel. I have recently run across that same panel. Also broken, we are temporarily triggering the bell circuits from a new (replacement) panel untill the remaining part of the building is renovated. Even Simplex doesn't have parts for that dinosaur. Check with the AHJ before trying to tie to new equipment.
Trade: Electrician
check with the fire marshal. You may be able to install a new panel next to the old one and tie into the existing appliance circuits using relay modules, or a relay board.
then the customer could begin upgrading one loop at a time. |
Trade: Low Voltage
Nethan,
I dealt with old FACP that was made by ADEMCO. Pretty similar to Simplex Grinnell. The panel itself was powered by 120vac however, the sensors (i.e.: pull stations, smoke detectors) are sometimes have a separate trigger cable. They usually use 4 conductor. 2 conductor power the sensor and the other pair is for trigger. Find out from your local fire marshall about replacing panel, if you need to replace all the wiring as well ($$$$). Good luck. |
| adding meter main panel?? | ko_jun | Electrical | 3 | 05-26-2007 10:42 PM |
| Sub panel | mjay | Electrical | 9 | 02-24-2006 11:41 PM |
| Upgrading Main Panel | DecksEtc | Electrical | 7 | 01-23-2006 07:54 PM |
| Where's my thread? (Politics anyone?) | AAPaint | Off Topic (Non Trade) | 175 | 08-16-2005 01:45 AM |
