Siemens Circuit Breakers
Old 09-28-2007, 12:23 AM   #1
Krashk2's Avatar
Trade: Renovations, Construction
I am adding a basement suite to a house and need more circuit breakers. I was wondering if anyone knows if Siemens has a smaller version of the 2 pole 15 amp breaker used for kitchen plugs. The existing breakers take up room for 4 15 amp single pole breakers
Krashk2 is offline
Old 09-28-2007, 07:01 AM   #2
mdshunk's Avatar
Re: Siemens Circuit Breakers
I wonder why you just wouldn't put in a small subpanel if you're out of spaces?
mdshunk is offline
Old 09-28-2007, 03:34 PM   #3
Krashk2's Avatar
Thanks for the reply. I was able to find the smaller breakers. They come in a group of 4 with the middle 2 breakers acting as double pole. I will have to do a little arranging but it should work fine
Krashk2 is offline
Old 09-28-2007, 04:16 PM   #4
GSE's Avatar
Trade: Electrical
Quote: "I am adding a basement suite to a house and need more circuit breakers."
I find it hard to believe, that the load has not changed, with the addition of a basement suite, just adding more breakers is not an answer, checking your added, and existing loads and planning your system is.
GSE is offline
Getting 15.6V on Dead Circuit - Why ???? nasTTcar Electrical 19 07-24-2007 05:32 AM
Counterfeit “Square D” Circuit Breakers CE1 Electrical 9 12-04-2006 08:53 AM
Inground pool light circuit louis bugaj Electrical 28 11-07-2006 11:19 PM
How many Breakers in a panel robertc65 Electrical 2 02-21-2006 02:09 PM
changing fuses to circuit breakers 747 Electrical 11 07-27-2005 01:10 PM
