Short-fault Vs Overcurrent Vs Arc-fault Devices
Old 12-20-2007, 09:13 PM   #1
Mark Twenhafel's Avatar
Trade: resi elec newbie
Kinda' a newbie question, here:
Was reading the Industrial Control Panel article in Ch 4 of the NEC today, and something stuck out at me--one of the subsections talking about overcurrent-protection devices being required seemed to draw a distinction as if short-fault protective devices, arc-fault protective devices and overcurrent protective devices are all distinct "flavors" of devices. I.e., as if you can go down to the supply house and get one of each.
I'm limited in my experience to pulling romex in residential, so sometimes I have to try to picture this stuff in the code that's outside of my experience.
I'm familiar with overcurrent protection devices--the familiar breakers that we put in the panelboard--but in my mind, breakers also serve as short-fault protection devices. And, if you order them GFCI, they are also ground-fault protection devices.
So, why does the code seem to imply that they are discrete, distinct devices--can they be?
Thanks,
Mark
Mark Twenhafel is offline
Old 12-20-2007, 09:31 PM   #2
Service & Repairs
Magnettica's Avatar
Trade: Electrician
Re: Short-fault Vs Overcurrent Vs Arc-fault Devices
An overcurrent protective device (circuit breaker), does three things:
1) Provides overload protection
2) Provides short-circuit protection
3) Provides ground fault protection
And then there's all kinds of different fuses (non-time delay, dual element, instantaneous trip, inverse time).
Magnettica is offline
Old 12-23-2007, 03:20 AM   #3
Timster's Avatar
Trade: General
How an afci basically works: iaei.org/subscriber/magazine/00_d/gregory.htm
I did a service call today where a heater in the living room arc faulted. Nothing happened except for disintegrating the wire nut.
Glad we put them in bedrooms now...
I guess I am not allowed to post a helpful link here, so paste the above into your browser; just add all that h t t p : / / w w w . stuff...
Timster is offline
Old 12-23-2007, 08:41 AM   #4
Electrical Contractor
Speedy Petey's Avatar
Trade: Electrical
Tim, you can post links.
You just can't post an advertising link.
HERE
Speedy Petey is offline
Old 12-23-2007, 09:48 AM   #5
Thanks, Timster, for the link. I had forgotten how informative that magazine is. I put it on my toolbar to keep it in clear view.
Old 12-23-2007, 01:57 PM   #6
Electric_Light's Avatar
Trade: student again
Thanks,
Mark
They have to put everything into one, since you can't cascade different breakers in the panel box realistically.
The wall outlet GFCI is actually GFCI only. It's basically a relay that is triggered by leakage current. It will not respond to over-current/shorts, this is acceptable, because it's cascaded with short/over-current protector upstream in the breaker panel.
The most basic breaker has a heat-activated bi-metallic material that responds to overheating from overload and it's affected by temperature extremes. It also has a coil inside. When there's a short, the very high current causes the coil to generate enough magnetic field to pull the circuit open. This is the magnetic portion of the breaker that responds instantaneously. The breaker itself will probably have a IR of 10,000A or so and should have the ability to handle the short circuit current of the circuit.
Fuses are disposable, but they can be made to have interruption rating that do not even compare to breakers. A Buss 1200A 600v fuse weighs around 4 lbs each and is rated to interrupt 200,000A @ 600v.
If you're not familiar with the idea of interruption rating, consider this. You've got a 12v electronic device that only uses 0.1A.
You can power it with 8 AA batteries or power it from a big car battery and the device would still run. If there's a short inside, the amount of current that's allowed to flow until the fuse can break the circuit is considerably different between the two. When the interruption rating is exceeded, the fuse/breaker will "break" but circuit continues to live through the arc and melt wires, blow up the fuse/breaker violently and start a fire.
Electric_Light is offline
My fault or the granite guy's? john elliott General Discussion 86 01-17-2011 03:48 AM
What kind of control devices do you use? avalon Outdoor Lighting 7 02-29-2008 11:12 PM
Who is at fault, Liability wise? Ed the Roofer Business 19 03-10-2007 12:26 PM
Arch fault breakers edirector Electrical 17 08-25-2006 03:27 PM
