#21 |
listen twice talk once!
Trade: electrician
Re: Shocked When Touching Bath Faucet
Sorry I did not see a list of options to choose from.
#22 | |
Service & Repairs
Trade: Electrician
Re: Shocked When Touching Bath FaucetQuote:
#23 |
See what happens when you ask a carpenter about an electrical problem
#24 |
I know that some older homes used the copper plumbing as grounds. This is not good for numerous reasons but could supply an answer to your problem.
I do little HV electrical on homes but have seen the results of these grounds on the plumbing.
#25 | |
Trade: electrician Phoenix AZ
It happens.
Just because it's within code doesn't make it safe. Just because it's against code doesn't make it unsafe. |
#26 |
Trade: Licensed Master Electrician
About 8 years ago my helper got nailed taking a shower when he touched the faucet handles. The floor was wet when this happened. When his dad called me over to check it out, I later found that the house was originally a ranch, but they added another story. Originally I thought it was a ground problem but found nothing. Later I decided to take my meter and read voltages from the faucet to ground, found nothing, but then I read from the tub to ground and got 100V. Since current drainage systems use PVC the tub was not grounded and also isolated from the faucets because they are on the wall. I decided to cut the ceiling out in the 1st florr under the tub and found a nail throught a piece of RX. The nail was always hot, but when the floor got wet it conducted to the metal tub.
#27 | |
Union Electrician
Trade: Inside Wireman
Though having this bond creates situations like this, it does in fact prevent them from being deadly. In a fault condition like this, unbalanced current will use the water pipe and anything else that completes the circuit. Current will use every path back to it's source that is available and distribute it's amps proportionately to the resistance on each of those paths. If the the low impedance bond between the water pipe and service were not in place then the person in the bathroom may feel a shock when no water is on the floor and possibly a fatal shock when standing in a puddle of water. And referrencing another thread; if the circuit or service were GFCI protected the problem would be seen without a shock ever being felt. I apologize for using your quote Teetor, didn't mean to sound like I'm harping on you
#28 | |
Trade: electrician
#29 | |
| Garden Tub faucet repl, Cutoff's @ the same time? | BACKWOODS | Plumbing | 1 | 04-25-2008 08:00 PM |
| upper bath | woodlover | Remodeling | 14 | 04-21-2008 10:55 PM |
| Bath Fitter & 1 800 Bathtub | cabela | Flooring | 2 | 12-05-2007 09:59 AM |
| Bath & Kitchen Remodeler wanted for Upstate SC | SCDreamMaker | Help Wanted or Looking For Work | 0 | 05-23-2007 10:50 AM |
| Moen faucet question | Robie | Plumbing | 2 | 04-02-2006 04:52 PM |
