Shared Neutral With A GFI
Old 02-24-2007, 06:24 PM   #1
Electrical Apprentice
darren's Avatar
Trade: Electrical
I have asked two different journeyman this question and have gotten two different answers.
Can you use a GFI on a multiwire circuit. One guy said no, then while working with another i hooked up 3 GFI on 3 differnt circuits and they were all shareing the same neutral.
What I want to do is replace all my plugs in my house to the grounded type but do it safe and proper. Instead of tracking down the first plug on the circuit and putting the GFI there I am wanting to put the GFI next to my electrical panel.
My plan is to bring a new piece of 3 wire out of the panel to two GFI, but of course the neutral would be shared. Then come out of the load side of the GFI with the orginal wire and that would continune on to my plugs.
Panel->14/3NMD90->Line side of 2 GFI->Load side of 2 GFI->orginal wire continues on/
I hope that makes sense, but will this work or does a GFI need its own neutral.
Thanks
darren is offline
Old 02-24-2007, 06:31 PM   #2
Electrical Contractor
Speedy Petey's Avatar
Trade: Electrical
Re: Shared Neutral With A GFI
You cannot do this if you are continuing with 14/3.
Meaning: Panel> 14/3> two GFIs> 14/3> other receptacles.
You MUST change to two separate 14/2's after the GFIs.
Speedy Petey is offline
Old 02-24-2007, 10:12 PM   #3
MSSI's Avatar
Trade: Electrician
Thanks
Crap I only wanted to quote a portion of this..havnt figured that one out yet..
But anyway...You want to do it safe and proper? it sounds like you have the inention of putting grounded receptacles on an ungrounded circut..
If there is no ground in the circut you are not supposed to use 3 prong recepts..regardles of gfi protection. check to sse if there are grounds in the recept. boxes.
MSSI is offline
Old 02-24-2007, 11:13 PM   #4
darren's Avatar
Trade: Electrical
Hey it is legal and safe to do it the way I am talking about, well at least to the Canadian Electrical Code it is legal and i assume what they say is a safe way to do it.
I do agree there is not an equipment ground but if i come by and touch the metal part of something that is shorted out that will trip the GFI.
Speedy that is what i was thinking. What will happen if I were to do that. My guess would be nuisence triping because the hot comeing in could be differnt then neutral going out without a fault somewhere.
darren is offline
Old 02-25-2007, 12:15 AM   #5
Union Electrician
Sparky Joe's Avatar
Trade: Inside Wireman
MSSi, replacing ungrounded receptacles with GFI's is perfectly legal.
And Darren, why not use GFI breakers? They make 2 pole types, pretty spendy but I imagine they cost less than rewiring your house with single wire circuits instead of multiwire circuits
Sparky Joe is offline
Old 02-25-2007, 09:12 AM   #6
darren's Avatar
Trade: Electrical
HeyJoe
I looked at useing the breakers and yes they are very expensive, a single pole was around 90 so i can only imagine what a 2 pole would be.
Also there is no room in my panel for it, i am useing thin federeal pioneers and if i remember correctly the gfi was the thicker kind and my panel is full.
darren is offline
Old 02-25-2007, 09:25 AM   #7
MSSI's Avatar
Trade: Electrician
10-4 I stand corrected then. Sorry for the bad info. Is there a code reference to that? I cant find it .
MSSI is offline
Old 02-25-2007, 09:29 AM   #8
darren's Avatar
Trade: Electrical
MMSi are you in Canada or the US, i can give you a reference for the canadian stuff.
darren is offline
Old 02-25-2007, 06:05 PM   #9
MSSI's Avatar
Trade: Electrician
Im in US...
Well thats good to know. I hate tying and crimping all those grounds togeather. Ill just start putting gfis in every circut and cut all those pesky little ground wires off....
MSSI is offline
Old 02-25-2007, 11:05 PM   #10
Union Electrician
Sparky Joe's Avatar
Darren, what you proposed in the original post (#1) about sharing neutrals on a GFI circuit will work as long as the neutrals are pigtailed at each device.
If you're trying to 'slave' other receptacles off the first or second GFI on that neutral you will have problems.
Old 02-25-2007, 11:27 PM   #11
MO-AMPS's Avatar
Trade: Electrician
I'm not uderstanding why you have to change the original branch circuit and according to you what do you change branch to
MO-AMPS is offline
Old 02-25-2007, 11:35 PM   #12
MO-AMPS's Avatar
Trade: Electrician
[quote
Originally Posted by MSSI View Post
Im in US...
Are referring to new construction if you are why would you use gfci I'm confuse with that thread or reply
MO-AMPS is offline
Old 02-25-2007, 11:36 PM   #13
Service & Repairs
Magnettica's Avatar
Trade: Electrician
See 406.3 (D)(3)
Magnettica is offline
Old 02-26-2007, 06:41 AM   #14
Trade: Electrical
First of all Mo your writing style is nearly impossible to comprehend. This is not a put down, it truly is constructive criticism.
Punctuation and writing in sentences will go a long way in helping others understand what you are trying to say.
Re-read my post you quoted. I was saying IF the original wire is 14/3, he cannot do it, and IF he insists on doing it that way he must change to wire to separate 14/2's. He already made it clear is changing the home run.
If the existing wiring is 14/2 then he is fine with changing the home run to 14/3 and feeding two GFI devices.
Old 02-26-2007, 09:43 AM   #15
MO-AMPS's Avatar
Trade: Electrician
First off you comprehended it well becaause you responded, so your little critism is really childish so grow-up.
Second if you read the original thread It never said where he was going to change t out the home-run.
MO-AMPS is offline
Old 02-26-2007, 04:21 PM   #16
Trade: Electrical
Quote from the original post:
Sorry MO that you cannot take some friendly constructive criticism. I was not being chilidsh, I was trying to help.
Your posts are almost illegible and at this point not worth the effort of trying to figure out.
I'm taking off my decoder ring now.
Old 02-26-2007, 11:35 PM   #17
MO-AMPS's Avatar
Trade: Electrician
Well it is obvious that you were not trying to help,because if you were you would've sent me a private message.
Your intention was to put me out in front of everybody,so I hope you learn some manner and stop nic-picking all my threads it is getting on my nerves Mr.Speedo.
But back to the original post, he is not changing the homerun read more careful next time you "moron"
MO-AMPS is offline
Old 02-27-2007, 06:41 AM   #18
Trade: Electrical
The issue at hand is also semantics. He running a new wire to pick up an existing circuit. This is replacing the home run, or adding another. It DOES NOT matter. The idea is the SAME thing.
What matters is what the cabing is after the new GFIs.
*Edit- I edited out any reply I made to your insults. I am done with you and will not "bother" you any more MO. Sorry for trying to help.
Old 02-27-2007, 06:11 PM   #19
mdshunk's Avatar
Originally Posted by MO-AMPS View Post
... Mr.Speedo.
Ewwww... that's a mental picture that I could have done without
When people get ticked at me, they call me "Skunk", which tickles me very much. Havn't heard that since grammar school.
mdshunk is offline
Old 02-28-2007, 12:38 AM   #20
MO-AMPS's Avatar
Trade: Electrician
Hey! Look we have taken the original thread and view it different:
(1) You viewed it as a new home-run
(2) I viewed as if the gfci was acting as a sub-panel of some sort
But who ever is correct really don't matter, because it is just an interpetation of the thread confusion.If my view was correct you would probaly be agreeing with me and vice-versa.
But if look through all my threads you been on me kinda tuff on me. I'm usually able to take it and move on ,but you caught on a bad day.I have to admit you've made me check my code book more often than usual and I appreciate that, just start using a little tack, "season your words with salt" it would be taken a lot better.
But hey! We cool sorry for the insults keep talking to me. Hell! you are making me a little sharper.
MO-AMPS is offline
55 volts on both hot and neutral, what the heck!? karma_carpentry Electrical 32 02-28-2009 09:12 AM
Need help with a shocking outside waterspout Badoish Electrical 23 12-27-2008 04:18 PM
Reverse feed a broken neutral - K & T wiring mdcorreia Electrical 3 04-06-2007 06:53 PM
Ground & Neutral is Hot Capt2 Electrical 27 01-15-2007 08:51 PM
breaking the neutral..GENNY INSTALL snapperhead Electrical 4 07-05-2006 10:58 PM
